Can't change color of object
Message 1 of 9
I try to change the color of circle but it looks like the if statement never reaches
I tried with different values for minim and maxim,same result..
(setq radiusN (cdr (assoc 40 edata))) ; radius
(setq avgN (/ (- maxim minim) 2))
(cond
((<= radiusN avgN )
(princ "here! 1")
(command "_.ChProp" edata "" "_C" 7 "")
( (> radiusN avgN)
(princ "here! 2")
(command "_.ChProp" edata "" "_C" 2 "")
Is there any way to rewrite the loop?
Replies (8)
Message 2 of 9
j.palmeL29YX
(command ...) doesn't understand edata as element to modify.
Try instead of edata this: (cdr (assoc -1 edata))
Code snip:
(command "_.ChProp" (cdr (assoc -1 edata)) "" "_C" 7 "")
HTH
cadder
Jürgen Palme
Message 3 of 9
I get the same results ,I think the problem is setting avgN and radiusN
(setq avgN (/ (+ maxim minim) 2))
because (>= radiusN avgN )  never returns true.
Message 4 of 9
j.palmeL29YX
We need more of your code. Where are maxim and minim and edata coming from?
Did you check the value of this variables?
Maybe this will do what you want:
(defun c:test ()
  (setq edata (entget (car (entsel "}nPick circle: "))))
  (setq    maxim 50
    minim 20
  (setq avgN (/ (- maxim minim) 2.))  ; avgN must be a real number, therefore 2.0
  (cond
    ((<= radiusN avgN)
     (princ "here! 1")
    ((> radiusN avgN)
     (princ "here! 2")
     (command "_.ChProp" (cdr (assoc -1 edata)) "" "_C" 2 "")
cadder
Jürgen Palme
Message 5 of 9
They are inputs
(setq minim (getint "Minimum radius:\n"))
(setq maxim (getint "Maximum radius:\n"))
Message 6 of 9
Your code looks like it works but mine still doesn't work.
Here is the full code
(defun C:circleChanger ( / objectsset center edata eid etype translategroup minim maxim ang colorN)
; ask the user to select a set of objects
(setq objectsset (ssget))
(initget 1)
(setq center (getpoint "Center of the action :\n"))
;(initget 1)
;(command "_.ChProp" objectsset "" "_C" 3 "")
; iterate over the selection set
(setq slen (sslength objectsset)
ix 0)
(setq avgN (/ (+ maxim minim) 2.))
(while (< ix slen)
(setq edata (entget (ssname objectsset ix))
eid (cdr (assoc -1 edata))
etype (cdr (assoc 0 edata))
(if (/= etype "CIRCLE") ; not a circle
(progn
(princ "Warning! [")
(princ eid)
(princ "] was not a [CIRCLE], but a [")
(princ etype)
(princ "]; skipped.\n")
) ; then - progn
(progn
(setq translategroup (assoc 10 edata)
edata (subst (cons 10 center) translategroup edata)
;(command "_.ChProp" ss "" "_C" usercol "")
;(setvar "hpscale" (cdr (assoc 41 edata))); SCALE
; (setvar "hpang" (cdr (assoc 52 edata))); ANGLE
; (setq radius (cdr (assoc 39 Ent))
(cond
((<= radiusN avgN)
(princ "here! 1")
(command "_.ChProp" (cdr (assoc -1 edata)) "" "_C" 1 "")
((> radiusN avgN)
(princ "here! 2")
; (princ radiusN)
; (princ avgN)
(setq ang 0)
(repeat 6
(command "PLINE"
(polar center ang (/ radiusN 2 (cos (/ pi 6))))
(polar center (+ ang (/ pi 6)) radiusN)
(polar center (+ ang (/ pi 3)) (/ radiusN 2 (cos (/ pi 6))))
(setq ang (+ ang (/ pi 3)))
(entmod edata)
(setq ix (1+ ix))
) ; while
(princ) ; don't return anything
Message 7 of 9
j.palmeL29YX
I did not yet check your code in detail. At first I did run it and got the attached result.
Isn't it what you want?
https://autode.sk/2HSMUDq
If this is not the expected, tell us what you want to get.
cadder
Jürgen Palme
Message 8 of 9
That is what I want but my code also creates stars in each circle,the stars work but the color don't .
Message 9 of 9
j.palmeL29YX
I added some lines (italic) in the repeat loop.
And substituted the (command "pline" ...)  with (command "_pline" ...) . Becauso of this lapsus the stars were not drawn in my german AutoCad.
    (repeat    6
      (command
        "_PLINE"
      (cond
        ((<= radiusN avgN)
                    ;(princ "here! 1")
         (command "_.ChProp" "l" "" "_C" 1 "")
        ((> radiusN avgN)
                    ;(princ "here! 2")
         (command "_.ChProp" "l" "" "_C" 2 "")
    (entmod edata)
    (setq ix (1+ ix))
  )                    ; while
Jürgen Palme
