Can lisp export attribute datas to a specific cell of excel?
smallƑish
Message 1 of 9
smallƑish
The attached DWG has has Attribute Block with 3 Tags
1. Sl NO
2. LOAD
3. QUANTITY
Can lisp export
TAG 2. LOAD value to Column B
TAG.3. QUANTITY value to Column C
By referring to TAG.1 Sl NO number order Excel Raw
Sample files are attached.
Replies (8)
Message 2 of 9
Sea-Haven
Yes. Been done many times, only thing is it will be a custom output as putting correct attribute into correct cell.
Ok the how to, select all blocks, and make a list of attributes, sort on, SL NO, then just fill in cells in a loop reading the list. Hint Putcell.
This has all the functions you need for the excel part just pull out the relevant defuns.
Do you want table creation as well ?
I will look into how to add formula to a cell so total works rather than just put a text value.
Message 3 of 9
smallƑish
can you please share any drawings and lisp that work with excel, any simple and small? hence I can study how it works.
Thank you
Message 5 of 9
smallƑish
Atleast can we do something to do attout, but with the order of serial number? Or a AutoCAD table.
Message 6 of 9
daniel_cadext
Sorry for the intrusion
IMHO, this is a job for Python, Openpyxl and Pandas
MS Office is not required, just create the xlsx directly.
import traceback
from pyrx_imp import Rx
from pyrx_imp import Ge
from pyrx_imp import Gi
from pyrx_imp import Db
from pyrx_imp import Ap
from pyrx_imp import Ed
import pandas as pd
#get the attribues and return them as a list
def getAttValues(ref: Db.BlockReference)->list[str]:
    v = []
    for attrefid in ref.attributeIds():
        attref = Db.AttributeReference(attrefid)
        match attref.tag():
            case 'SL':
                v.append(attref.textString())
            case 'LOAD':
            case 'QTY':
            case _:
                pass
    return v
def PyRxCmd_doit():
    try:
        db = Db.curDb()
        #define our columns
        data = {'SL#': [],
                'Unit Weight': [],
                'QTY': [],
                'Total KG': [],}
        #search for blocks 'MACHINE WEIGHT'
        bt = Db.BlockTable(db.blockTableId())
        spkIds = [id for (n, id) in bt.toDict().items() if n == 'MACHINE WEIGHT']
        for id in spkIds:
            btr = Db.BlockTableRecord(id)
            for refid in btr.getBlockReferenceIds():
                ref = Db.BlockReference(refid)
                values = getAttValues(ref)
                #pandas wants equal length lists
                if len(values) != 3:
                    continue
                data['SL#'].append(values[0])
                data['Unit Weight'].append(values[1])
                data['QTY'].append(values[2])
                total = float( float(values[1]) * float(values[2]))
                data['Total KG'].append(total)
        df = pd.DataFrame(data)
        df.loc['total']= df.sum(numeric_only=True)
        #write to excel
        with pd.ExcelWriter('e:\\pandas_to_excel.xlsx') as writer:
            df.to_excel(writer, sheet_name='sheet1',index=False)
    except Exception as err:
        traceback.print_exception(err)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 7 of 9
Sea-Haven
Being multi posted need to look at dwg BLOCKS also that has more common blocks in it.
Just a comment changing the attribute order would be a good idea so they match the drawn view would be my 1st step.
Using Bricscad  Bedit Battman move SL NO with up arrow Apply & Sync.
Message 8 of 9
Sea-Haven
(defun c:wow ( / xlsetcelltext ss lst lst2 myxl str row)
;;	Thanks to fixo			;;
;;   = Set Excel cell text =    ;;
(defun xlsetcelltext ( row column text)
(setq cells (vlax-get-property  (vlax-get-property myxl "ActiveSheet") "Cells"))
  (vl-catch-all-apply
    'vlax-put-property
    (list cells 'Item row column
	(vlax-make-variant (vl-princ-to-string text) vlax-vbstring)))
(setq ss (ssget '((0 . "INSERT"))))
(if (= ss nil)
(progn (alert "No blocks selected will exit")(exit))
(setq lst '())
(repeat (setq x (sslength ss))
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq atts (vlax-invoke obj 'Getattributes))
(setq lst2 '())
(foreach att atts
(setq str (vlax-get att 'textstring))
(setq lst2 (cons str lst2))
(setq lst (cons (reverse lst2) lst))
(setq lst (vl-sort lst
	 '(lambda (a b)
	    (cond
	      ((< (car a) (car b)))
	      ((= (car a) (car b)) (< (cadr a) (cadr b)))
(or (setq myxl (vlax-get-object "Excel.Application"))
    (setq myxl (vlax-get-or-create-object "excel.Application"))
(vlax-invoke-method (vlax-get-property myXL 'WorkBooks) 'Add)
(vla-put-visible myXL :vlax-true)
(vlax-put-property myxl 'ScreenUpdating :vlax-true)
(vlax-put-property myXL 'DisplayAlerts :vlax-true)
(setq row 1)
(xlsetcelltext 1 1 "Room")
(xlsetcelltext 1 2 "SL")
(xlsetcelltext 1 3 "Table")
(xlsetcelltext 1 4 "CHAIR")
(setq row 2)
(foreach val lst
(xlsetcelltext row 1 (nth 0 val))
(xlsetcelltext row 2 (nth 1 val))
(xlsetcelltext row 3 (nth 2 val))
(xlsetcelltext row 4 (nth 3 val))
(setq row (1+ row))
(if (not (vlax-object-released-p myXL))(progn(vlax-release-object myXL)(setq myXL nil)))
(princ)
(c:wow)
Message 9 of 9
smallƑish
@Sea-Haven
Thank you so much for the code, Looks like much more complicated stuff is included in it. Hope many users can take the code as a reference to develop code as per their requirements referring to it. Again many thanks.
