Can I insert attribute in all current opened drawing's layout?
skchui6159
Message 1 of 48
skchui6159
(defun reptag (tag newvalue ent / alist )
(if (and (= (type ent) (read "VLA-OBJECT")) newvalue)
(progn
(setq alist ( vlax-invoke ent 'GetAttributes))
(foreach a alist
(if (= (vla-get-tagstring a) tag)
(vlax-put-property a 'TextString newvalue)
);i
);fe
);p
(if (= 'ename (type ent)) (reptag tag newvalue (vlax-ename->vla-object ent)));i
);i
(princ));d
(defun c:OS ( / ent ss1)
;(setq ent (car (entsel)))
(foreach Layout (layoutlist)
(setq dateofinput "07/24")
(setq ss1 (ssget '(788 190 0)))
(setq ent (ssname ss1 0))
(reptag "ORIGINAL" "ORIGINAL" ent)
(reptag "SIGNED" "SIGNED" ent)
(reptag "GSTAUTHDATE" dateofinput ent)
(reptag "GSTFCHECKDATE" dateofinput ent)
(reptag "GST2CHECKDATE" dateofinput ent)
(reptag "GST1CHECKDATE" dateofinput ent)
(reptag "GSTDRAWDATE" dateofinput ent)
); foreach end
(princ))
The above lisp can run only single layout, but I want to apply all current opened drawing's? Anyone can help? Thx
Replies (47)
Message 2 of 48
paullimapa
If you have an entire folder of dwgs that you need to run your code on you can try:
Script Writer | Lee Mac Programming (lee-mac.com)
Paul Li
IT Specialist
@The Office
Message 3 of 48
skchui6159
Can you get me a example for write the script? Can it use in .LSP?😅
Message 4 of 48
paullimapa
It’s easy. The line of script is similar to the example shown on link I provided in my previous post. The difference is that you have to include statements to load your lisp  and the command to run it. So assuming your lisp file is called OS.lsp and is saved in one of the folders in AutoCADs Support file search path then the Script Writer edit box would look something like this:
_.Open *file* (load"OS") (c:OS) _.Qsave _.Close
Paul Li
IT Specialist
@The Office
Message 5 of 48
skchui6159
Thx, Also I will to ask that there are no any response for the above lisp for the (foreach Layout (layoutlist), I will to use the function in all layout, but only the current layout give me the response. Any problem in my lisp?
Message 6 of 48
paullimapa
to make a layout current you need to include this code:
  (setvar "ctab" Layout) ; where Layout is an item from the list above
Paul Li
IT Specialist
@The Office
Message 7 of 48
pbejse
Unless there are multiple instance of the target block per layout tab [ which i doubt ], you are better off using a block name filter, instead of a point list, also you don't need to switch tab to edit the block
@skchui6159 wrote:
...(reptag "ORIGINAL" "ORIGINAL" ent)
We can modify reptag function to accept a data list instead of repeatedly invoking the function for every TAG name
That is definitely doable.
Message 8 of 48
skchui6159
It is my blank title block attached.
It is multiple instance in Initial.
I have corrected the lisp code.
No any response in other tab again.
Any revise can you advise?
My block name is "TITLE BLOCK-A".
(progn
(foreach a alist
);i
);fe
);p
);i
(princ));d
); foreach end
(princ))
Message 9 of 48
paullimapa
try this updated code:
; OS updates attributes on all blocks found matching given name
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/can-i-insert-attribute-in-all-current-opened-drawing-s-layout/m-p/12916173#M469166
(defun c:OS ( / dateofinput ent i obj reptag ss1)
 (setq blknam "TITLE BLOCK-A"
       dateofinput "07/24"
 ) ; setq
 (vl-load-com)
   (progn
    (foreach a alist
     );i
    );fe
   );p
  );i
  (princ)
 );d
 (if(setq ss1 (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat blknam ",`*U*")) '(66 . 1))))
  (progn
    (setq i 0)
    (repeat (sslength ss1)
      (setq ent (ssname ss1 i)
            obj (vlax-ename->vla-object ent)
      (if (eq blknam (vla-get-effectivename obj))
        (progn
        ) ; progn
      ) ; if
      (setq i (1+ i))
    ) ; repeat
    (princ(strcat"\nUpdated Blocks matching: " blknam))
  ) ; progn
  (princ(strcat"\nThere are no Blocks found matching: " blknam))
 ) ; if
(princ)
) ; defun
Paul Li
IT Specialist
@The Office
Message 10 of 48
skchui6159
It works , many thank!
Could you please explain the above lisp?
Message 11 of 48
paullimapa
Well at the top of the code is where the block name and date is defined I placed it there so it’ll be easier for you to modify in the future
       dateofinput "07/24"
Then I used a selection set filter to select all instances of your block name including dynamic blocks since that’s what your title block contains:
this filters also only blocks with attributes
then if selection set is found I have to check each selected item to make sure the dynamic block selected matches your block name:
 (setq i 0)
then if a match is found it’ll cycle through your function to fill in the matching attribute tag with corresponding values
        (progn
        ) ; progn
      ) ; if
Paul Li
IT Specialist
@The Office
Message 12 of 48
pbejse
As i describe on my previous post, the reptag subfunction will now accept a list.
Do you still want to to run on this on opened files?
We wrote this code in VL so we can processed files on opened drawings and even files in a folder
(defun c:OS (/ reptag dateofinput attV)
(defun reptag (lst attbLst  / found)
 (foreach itm attbLst
   (if (setq found (assoc (Car itm) lst))
     	(vla-put-textstring (Cadr itm)(cadr found)))
  (princ)
(vlax-for blk (vla-get-blocks (vla-get-ActiveDocument (vlax-get-acad-object)))
		(cond
		  ((minusp (vlax-get blk 'isXref)))
		  ((vlax-for h blk
		     (cond
		       ((null (vlax-write-enabled-p h)))
		       ((and
			  (eq (vla-get-ObjectName h) "AcDbBlockReference")
			  (minusp (vlax-get h 'HasAttributes))
			  (wcmatch (vla-get-EffectiveName h) "TITLE BLOCK-*" )
			  (setq attV (mapcar '(lambda (at)
						(list (vla-get-tagstring at) at))
						(Vlax-invoke h 'GetAttributes)))
			(reptag (append '(("ORIGINAL" "ORIGINAL")("SIGNED" "SIGNED"))
			  		(mapcar '(lambda (v)(list v dateofinput))  '("GSTAUTHDATE" "GSTFCHECKDATE"
									"GST2CHECKDATE" "GST1CHECKDATE" "GSTDRAWDATE")))
			   attV
  (princ)
HTH
Message 13 of 48
skchui6159
Very Helpful! Thank you very much! it works
Message 14 of 48
skchui6159
Why the some drawings shown the above program if I run a lisp?
How to fix it?
_.Open *file* (load "Rep222") (c:REP222) _.Qsave _.Close
If I write below that, it will stop the program.
_.Open *file* (load "Rep222") (c:REP222) _.Qsave _.Close N
Message 15 of 48
skchui6159
if some autocad file shown these message, I can write the "N" of the script but some drawing not show the above message, so the scripts stoped.
Message 16 of 48
paullimapa
you will have to troubleshoot which drawings cause the problem.
perhaps some other users have those drawings open while you're trying to access?
also is the problem related to the lisp "Load failed"
Paul Li
IT Specialist
@The Office
Message 17 of 48
skchui6159
The problem was solved. Lisp can write the _.qsave and _.close in program. I write the command at the end of program. Like that
(command "_.qsave")
(command ".close" "N")
);defun end
wscript works. The program was not stopped.
Message 18 of 48
skchui6159
A more question, if I want to insert attribute on model space only?
Message 19 of 48
paullimapa
then you'll have to replace this line of code:
to this which will only select blocks in Model tab:
(if(setq ss1 (ssget "_X" (list '(0 . "INSERT") (cons 2 (strcat blknam ",`*U*")) '(66 . 1) '(410 . "Model"))))
Paul Li
IT Specialist
@The Office
Message 20 of 48
skchui6159
If I want to make the drawing no to (strcat "ABC/1/BL6/S" (getvar ('ctab))) and the case 2, how to do?
there are no response (In this condition only BM-111 ok, but other layouts are no response.) if i correct the above program.
Case 1: ABC/1/BL6/S/BM-111
Case 2: ABC/1/BL6/S/BM-111/A
I used the foreach function of lisp for the above conditions, no response. Can you assist, thank you?
