Can I have lines dimensioned, and automated as I draw
paul.patersonhill
Observer Observer
paul.patersonhill
Observer
Observer
Hi all,
With Autocad, I am using lines to display pipework.
When I draw the lines out, for my pipework design. Then go back to dimension it all with a desired font, colour, height, position. I get that I can make a dim-style and then that will be okay for the rest of the way with that dim-style. But how can I obtain this to be displayed on my lines that I am drawing as I make a new line?
Furthermore could I dare say it would be possible to have the pipe's diameter, finish, and threaded / grooved end information from each line I draw, displayed in excel?
I spend quite a lot of time going back and forth and double checking. In hopes to make things a little easier and more appealing to look at when reviewing.
Sea-Haven
Part 1 draw line and dimension YES
Part 2 provided the dimensions have all the detail then yes can do direct to Excel .
Totally guessing what you have need a sample dwg may need also pop dcl for input choices.
