Im not sure if Im saying that right. I use this little snippet of code in a lot of programs (with different lists of course depending on the program). As I understand it, the part that reads <POOL> and ("POOL") define the default choice in the display and the selection. Ive removed those and there is no default, you must select something. What I want to know is if there is a way to use that part of the code to make the selection whatever the last selection was, instead of a defined default or none. Thank you
(IF (NULL TYP)
(PROGN (INITGET "POOL SPA THERAPY WTR-FEATURE")
(SETQ TYP (COND ((GETKWORD "\nSpecify Layer [POOL/SPA/THERAPY/WTR-FEATURE] <POOL>: "))
("POOL")
