Calling sub function syntax
Message 1 of 8
I've never written a lisp with a subfunction within it before, please can someone check the following syntax is correct?
I know it's not very ambitious to say the least but if I can get the basics right then subsequent lisps might stand a chance
(defun c:aaa ()
    (alert "this is aaa")
   (bbb)
      (alert "this is aaa again")
  (princ)
(defun c:bbb ()
    (alert "this is bbb")
Replies (7)
Message 2 of 8
ВeekeeCZ
If you're about calling your bbb sub multiply just from main c:aaa routine, then something like this. Put it inside of c:aaa and localize bbb.
Spoiler
(defun c:aaa ( / bbb)
  (defun bbb ()
  ; main program
  (bbb)
  (princ)
But if you about to call bbb from other routines as well (e.g. c:ccc), then use this:
Spoiler
(defun c:aaa ()
  (bbb)
  (princ)
(defun c:ccc ()
  (alert "this is ccc")
  (bbb)
  (alert "this is ccc again")
  (princ)
(defun bbb ()
And if you want to call bbb separately as command as well, use c: prefix. But usually you don't...
Spoiler
(defun c:aaa ()
  (c:bbb)
  (princ)
(defun c:bbb ()
    (alert "this is c:bbb")
Message 3 of 8
Thanks ever so for that.
I'll definitely be keeping this page in my Favourites to refer to again !
Message 4 of 8
Kent1Cooper
You can either define bbb without the C: prefix, as already suggested, or you can use it with the C: prefix:
(defun c:aaa ()
  (c:bbb)
  (princ)
(defun c:bbb ()
The advantage of that is that, if you want to, you can enter bbb itself as a command name.  If it's defined without the C: prefix, to use it on its own you need to call it with the parentheses:
Command:  (bbb)
Kent Cooper, AIA
Message 5 of 8
Thanks for that Kent, it's all clear to me now. My mistake was that I referred to other people lisps, but couldn’t work out why my little test lisp failed. All the other folks lisps don’t have the c: at the beginning of their sub functions & I didn’t notice. I’m so used to starting a function these days with:
(defun c:my_func ()
that it’s become automatic.
I couldn’t find much about it with a Google either.
Message 6 of 8
ВeekeeCZ
How about help! 🙂
Message 7 of 8
doni49
When writing a routine that I think might be useful to be called from another routine, but also one that I want to use as a command unto itself, I usually write it WITHOUT the c: (what I refer to as a performing function) and then write a function that gathers the user input and then passes it to the other function (aka a gathering function).  For example:
;;This is how a routine might normally be written as a command.
(defun c:mycommand ( / ents var1 var2)
  (setq ents(ssget))
  (setq var1 (getpoint "Point1:  "))
  (setq var2 (getpoint "Point2:  "))
  (command "move" ents "" var1 var2)
;;now if I want to make it so that a different routine can gather the user input
;;(and probably do other things too) then perform the tasks, I would break it
;;into a performing function and a gathering function.
;;this is the gathering function.
(defun c:mycommand( / ents var1 var2)
  (setq ents(ssget))
  (mycommand ents var1 var2) ;; <--it might look like it's calling itself.
                                                  ;;     But it's calling the performing function
;;this is the performing function
(defun mycommand (ents var1 var2)
  (command "Move" ents "" var1 var2)
 This is just one example as to why both styles are useful.
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
Message 8 of 8
scot-65
Next.
Try this as a function with a call:
(defun c:AAA ()
(alert "this is a")
(bbb "This is bbb-1")
(alert "this is a")
(bbb "This is bbb-2")
(alert "this is a")
(princ)
(defun bbb ( a / )
(alert a)
bbb cannot be a command in this instance because
of the call (item in front of the forward slash).
Next.
Function returns a value:
(defun c:AAA ()
(alert (bbb))
(defun bbb ()
"This is bbb-3"
Another way to do this:
(defun bbb ()
(setq b "this is bbb-4")
(princ)
b
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
