calling a defun c: and prompts
anieves228
Message 1 of 11
anieves228
Hiya!
question for you all so I'm calling a c: in my script called Polyline Diet (It reduces the amount of node in a polyline .ill post to share) and I'm trying to fill out the values:
Maximum distance between non-collinear vertices to straighten <1000>:
Maximum change in direction to straighten <2>:
Retain or Straighten arc segments [R/S] <R>:
Select LWPolylines to put on a diet, or press Enter to select all: Also to force end the command here so it can move onto the next.
My script converts the line into a polyline then runs PLD to reduces the nodes then turns it back into a spline. done. BUti can fill in the values above.
Bonus: if you know how to keep the same selection the whole without selecting the line 3 time that would be great!
The red is my issue
Here is my script:
	(DEFUN C:SPLD()
		(command "-osnap" "off")
		(command "pselect" pause "")
			(COMMAND
				"PEDIT"
				"y"
				"10"
			(C:PLD()
			"10000000000000000"
			"2"
			"r"
			(COMMAND
				"PEDIT"
				"SPLINE"
		(command "-osnap" "End,Mid,Cen,Node,Quad,Int,Ins,Perp,Tan,Gcen,AppInt,Ext")
		(princ)
Replies (10)
Message 2 of 11
dbhunia
Hi
As you want......
@anieves228 wrote:
Hiya!
This is a sample code how to use multiple command by selecting single times......(here I am using 2 command by single selection).......Because I don't know what is "pselect" or "C:PLD".....
(defun C:test (/)
(Setq selectionset (ssget))
(command "move" selectionset "" (getpoint "\nBsae Point to Move: ") (getpoint "\nPoint to Move: "))
(command "copy" selectionset "" (getpoint "\nBsae Point to Copy: ") (getpoint "\nPoint to Copy: "))
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 11
ronjonp
Untested but this should work .. usage at the end:
;;;  PLDIET.lsp [command name: PLD]
;;;  To put lightweight PolyLines on a DIET (remove excess vertices); usually
;;;    used for contours with too many too-closely-spaced vertices.
;;;  Concept from PVD routine [posted on AutoCAD Customization Discussion
;;;    Group by oompa_l, July 2009] by Brian Hailey, added to by CAB, and
;;;    WEED and WEED2 routines by Skyler Mills at Cadalyst CAD Tips [older
;;;    routines for "heavy" Polylines that won't work on newer lightweight ones];
;;;    simplified in entity data list processing, and enhanced in other ways [error
;;;    handling, default values, join collinear segments beyond max. distance,
;;;    limit to current space/tab, account for change in direction across 0 degrees,
;;;    option to keep or eliminate arc segments] by Kent Cooper, August 2009.
;;;  Last edited 28 August 2013
(defun pld (*distmax* *cidmax*	*arcstr* flag  /	    *error*   cmde	disttemp  cidtemp
	    arctemp   plinc	plsel	  pl	    pldata    ucschanged	  front
	    10to42    vinc	verts	  vert1	    vert2     vert3
  (defun *error* (errmsg)
    (if	(not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    )					; end if
    (if	ucschanged
      (command "_.ucs" "_prev")
    )					; ^ i.e. don't go back unless routine reached UCS change but didn't change back
    (command "_.undo" "_end")
    (setvar 'cmdecho cmde)
  )					; end defun - *error*
  (setq cmde (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (command "_.undo" "_begin")
;;;  (setq	disttemp  (getdist (strcat "\nMaximum distance between non-collinear vertices to straighten"
;;;				   (if *distmax*
;;;				     (strcat " <" (rtos *distmax* 2 2) ">")
;;;				   )	; default only if not first use
;;;			   )		; end strcat
;;;		  )			; end getdist & disttemp
;;;	*distmax* (cond	(disttemp)	; user entered number or picked distance
;;;			(*distmax*)	; otherwise, user hit Enter - keep value
;;;		  )			; end cond & *distmax*
;;;	cidtemp	  (getangle (strcat "\nMaximum change in direction to straighten"
;;;				    (strcat
;;;					; offer prior choice if not first use; otherwise 15 degrees
;;;				      (if *cidmax*
;;;					(angtos *cidmax*)
;;;					(angtos (/ pi 12))
;;;				    )	; end strcat
;;;			    )		; end strcat
;;;		  )			; end getdist & cidtemp
;;;	*cidmax*  (cond	(cidtemp)	; user entered number or picked angle
;;;			(*cidmax*)	; Enter with prior value set - use that
;;;			((/ pi 12))	; otherwise [Enter on first use] - 15 degrees
;;;		  )			; end cond & *cidmax*
;;;	plinc	  0			; incrementer through selection set of Polylines
;;;  )					; end setq
;;;  (initget "Retain Straighten")
;;;  (setq	arctemp	 (getkword (strcat "\nRetain or Straighten arc segments [R/S] <"
;;;				   (if *arcstr*
;;;				     (substr *arcstr* 1 1)
;;;				     "S"
;;;				   )	; at first use, S default; otherwise, prior choice
;;;			   )		; end strcat
;;;		 )			; end getkword
;;;	*arcstr* (cond (arctemp)	; if User typed something, use it
;;;		       (*arcstr*)	; if Enter and there's a prior choice, keep that
;;;		       ("Straighten")	; otherwise [Enter on first use], Straighten
;;;		 )			; end cond & *arcstr*
;;;  )					; end setq
;;;  (prompt "\nSelect LWPolylines to put on a diet, or press Enter to select all: ")
  (if flag
    (setq plsel (ssget "X" (list '(0 . "LWPOLYLINE") (cons 410 (getvar 'ctab)))))
    (setq plsel (ssget '((0 . "LWPOLYLINE"))))
  )					; end cond
  (setq plsel (ssget "X" (list '(0 . "LWPOLYLINE") (cons 410 (getvar 'ctab))))) ;
  (repeat (sslength plsel)
    (setq pl (ssname plsel plinc))
    (while (equal (vlax-curve-getstartpoint pl) (vlax-curve-getpointatparam pl 1) 1e-6)
					; to correct for possibility that more than one vertices at beginning coincide,
					; in which case Pline does not define a CS under UCS OBject, causing error
      (command "_.pedit" pl "_edit" "_straighten" "" "" "_go" "_exit" "")
    )					; while
    (setq pldata (entget pl))
    (if	(/= (cdr (last pldata)) (trans '(0 0 1) 1 0)) ; extr. direction not parallel current CS
					; for correct angle & distance calculations [projected onto current construction
					; plane], since 10-code entries for LWPolylines are only 2D points:
      (progn (command "_.ucs" "_new" "_object" pl) ; set UCS to match object
	     (setq ucschanged t)	; marker for *error* to reset UCS if routine doesn't
      )					; end progn
    )					; end if
    (setq front				; list of "front end" [pre-vertices] entries, minus entity names & handle
		 (vl-remove-if
		   '(lambda (x) (member (car x) '(-1 330 5 10 40 41 42 210))) ; end lambda
		   pldata
		 )			; end removal & front
	  10to42			; list of all code 10, 40, 41, 42 entries only
		 (vl-remove-if-not
		   '(lambda (x) (member (car x) '(10 40 41 42))) ; end lambda
		   pldata
		 )			; end removal & 10to42
	  vinc	 (/ (length 10to42) 4)	; incrementer for vertices within each Polyline
	  verts	 nil			; eliminate from previous Polyline [if any]
    )					; end setq
    (if	(= *arcstr* "Straighten")
      (progn (setq bulges		; find any bulge factors
		    (vl-remove-if-not
		      '(lambda (x)
			 (and (= (car x) 42) (/= (cdr x) 0.0)) ; end and
		       )		; end lambda
		      10to42
		    )			; end removal & bulges
	     )				; end setq
	     (foreach x bulges (setq 10to42 (subst '(42 . 0.0) x 10to42)))
					; straighten all arc segments to line segments
      )					; end progn
    )					; end if
    (repeat vinc
      (setq verts			; sub-group list: separate list of four entries for each vertex
		  (cons	(list (nth (- (* vinc 4) 4) 10to42)
			      (nth (- (* vinc 4) 3) 10to42)
			      (nth (- (* vinc 4) 2) 10to42)
			      (nth (1- (* vinc 4)) 10to42)
			)		; end list
			verts
		  )			; end cons & verts
	    vinc  (1- vinc)		; will be 0 at end
      )					; end setq
    )					; end repeat
    (while (nth (+ vinc 2) verts)	; still at least 2 more vertices
      (if (or				; only possible if chose to Retain arc segments
	    (/= (cdr (assoc 42 (nth vinc verts))) 0.0) ; next segment is arc
	    (/= (cdr (assoc 42 (nth (1+ vinc) verts))) 0.0) ; following segment is arc
	  )				; end or
	(setq vinc (1+ vinc))		; then - don't straighten from here; move to next
	(progn				; else - analyze from current vertex
	  (setq	vert1 (cdar (nth vinc verts)) ; point-list location of current vertex
		vert2 (cdar (nth (1+ vinc) verts)) ; of next one
		vert3 (cdar (nth (+ vinc 2) verts)) ; of one after that
		ang1  (angle vert1 vert2)
		ang2  (angle vert2 vert3)
	  )				; end setq
	  (if (or (equal ang1 ang2 0.0001) ; collinear, ignoring distance
		  (and (<= (distance vert1 vert3) *distmax*)
					; straightens if direct distance from current vertex to two vertices later is
					; less than or equal to maximum; if preferred to compare distance along
					; Polyline through intermediate vertex, replace above line with this:
					; (<= (+ (distance vert1 vert2) (distance vert2 vert3)) *distmax*)
		       (<= (if (> (abs (- ang1 ang2)) pi) ; if difference > 180 degrees
			     (+ (min ang1 ang2) (- (* pi 2) (max ang1 ang2)))
					; then - compensate for change in direction crossing 0 degrees
			     (abs (- ang1 ang2)) ; else - size of difference
			   )		; end if
			   *cidmax*
		       )		; end <=
		  )			; end and
	      )				; end or
	    (setq verts (vl-remove (nth (1+ vinc) verts) verts))
					; then - remove next vertext, stay at current vertex for next comparison
	    (setq vinc (1+ vinc))	; else - leave next vertex, move to it as new base
	  )				; end if - distance & change in direction analysis
	)				; end progn - line segments
      )					; end if - arc segment check
    )					; end while - working through vertices
    (setq front	 (subst (cons 90 (length verts)) (assoc 90 front) front)
					; update quantity of vertices for front end
	  10to42 nil			; clear original set
    )					; end setq
    (foreach x verts (setq 10to42 (append 10to42 x)))
					; un-group four-list vertex sub-lists back to one list of all 10, 40, 41, 42 entries
    (setq pldata (append front 10to42 (list (last pldata))))
					; put front end, vertex entries and extrusion direction back together
    (entmake pldata)
    (entdel pl)				; remove original
    (setq plinc (1+ plinc))		; go on to next Polyline
    (if	ucschanged
      (progn (command "_.ucs" "_prev")
	     (setq ucschanged nil)	; eliminate UCS reset in *error* since routine did it already
      )					; end progn
    )					; end if - UCS reset
  )					; end repeat - stepping through set of Polylines
  (princ)
)					; end defun - PLD
(prompt "\nType PLD to put PolyLines on a Diet.")
;; Usage
;; (pld 10000000000000000 2 "Retain" T)
Message 4 of 11
Kent1Cooper
As the author of PLDiet, I regret to inform @anieves228 that a command defined with the C: prefix can't be used in that way -- feeding in the answers to the prompts.  Only native AutoCAD commands used in (command) functions work that way.  @ronjonp has taken a shot at converting it into a function that takes arguments, by removing the
C: in the (defun) line, and taking out all the prompts for options and leaving them to be supplied as arguments.  You can therefore use it in an AutoLisp routine as they illustrate at the end [in parentheses, supplying values for the arguments], but I have two comments.  [I haven't loaded and tested it, either, so there could be other things....]
1)  [very unimportant]  I would change the term "command name" at the top to "function name" since it's not a command  definition any more.
2)  [more significant]  The last part quoted above makes it always work on every Polyline  in the current space [what you get if you hit Enter for that in the PLD command ].  @anieves228, am I correct that you want it to work on only the one  you've selected and are doing other things to?  If so, would you always  want to use it that way, or might you sometimes want to use it on all Polylines?  As adjusted, there's no provision for an argument about whether to work on a User selection or all of them, but it could be made to have that option.
Kent Cooper, AIA
Message 5 of 11
ronjonp
Code updated above .. use T for all and nil for a selection.
Message 6 of 11
dbhunia
Hi
I got the "Polyline Diet" lisp from......
http://cadtips.cadalyst.com/linear-objects/polyline-diet
If this is your "Polyline Diet" lisp, then try this.......(Modified code)
Debashis Bhunia
Message 7 of 11
anieves228
Hi Kent!
well first off PLD is amazing! I'm a complete noob with lisps. I've been learning them for about a month now
 I'm just trying to make it one command to turn a line into a polyline then run PDL then turn it back into a spline. Yes, I'll be using it on one line, not all polylines. Maybe in the future, that will change, but not at the moment.
Message 8 of 11
anieves228
Yes, that's where I downloaded it from. I'll give it a try thanks!
Message 9 of 11
Kent1Cooper
@Kent1Cooper wrote:
As the author of PLDiet, ....
... I have improved/enhanced it -- new version >here<.
Kent Cooper, AIA
Message 10 of 11
john.uhden
Note:
You can't call a C:function as an AutoCAD command and expect to feed it responses to internal imputs.
You would have to either...
a) rewrite the function to accept the inputs as arguments to the function, or
b) use (vlax-add-cmd) to make it an AutoCAD command.  Look it up in your help.
John F. Uhden
Message 11 of 11
Sea-Haven
Here is an alternative have a look at screenshot. Change the "h" to "v" and dcl will be vertical.
(if (not AH:Butts)(load "Multi Radio buttons.lsp"))
(if (= but nil)(setq but 1))
(setq ans (ah:butts but "h"  '("1 all or exit" "Pick 1" "All" "Exit"))) ; ans holds the button picked value
Use dlanorth "cond" and look at what is returned in variable ans.
