call a fas file in a ScriptPro.
mruPRQUJ
mruPRQUJ
Hi there,
Could you please advise me how to call a fas file in ScriptPro? Thank you very much in advance.
paullimapa
you need to create a script file that's a text file with extension .scr
then within the contents of the script file assuming the fas file is test.fas:
(load"test.fas")
This also assumes  test.fas is located in one of the folders defined under Options>Files>Support File Search Path and Options>Files>Trusted Locations
And remember to include an enter to complete the command in the script before saving.
Paul Li
IT Specialist
@The Office
mruPRQUJ
Hi there,
It looks like it did not work. The fas file name is "BCH_H_Reporting". The script file name is "call fas.scr". The script  content is below
(load"BCH_H_Reporting.fas")
two images are below.
Do I need to add "qsave"?
Thanks a lot!
paullimapa
Add 2nd line the name of the command to run BCH_H_Reporting.fas
And if you do want to save the file definitely add qsave command at the end.
for example if command is BCH_H_Reporting then your script file should contain:
(c:BCH_H_Reporting)
_.Qsave
or:
BCH_H_Reporting
_.Qsave
Paul Li
IT Specialist
@The Office
mruPRQUJ
Great job! It works perfect, thank you very much! 🙂
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
mruPRQUJ
cheers!!!
