calculate the area of the hatchs
trezatreza
Message 1 of 12
trezatreza
Hi all,
Please can you help me, I want to calculate the area of the hatchs, And it gives me in the command window (As the attached picture)
Thank you so much in advance
Replies (11)
Message 2 of 12
Sea-Haven
This is a quick 1 does 1 hatch layer at a time
(Defun C:AHAT (/ arean  lay sset)
(setvar 'ctab "Model")
(setq Hp (ENTGET (CAR (ENTSEL "\nPICK HATCH "))))
(SETQ LAY (CDR (ASSOC 8 HP)))
(setq ssEt (ssget "x" (list (cons 0 "Hatch") (CONS 8 LAY)(cons 410 "Model"))))
(setq arean 0.0)
(REPEAT (setq num (sslength sset))
(setq en (ssname sset (setq num (- num 1))))
(SETQ ARNEW (vla-get-area (vlax-ename->vla-object en)))
(setq AREAN (+ AREAN ARNEW))
(ALERT (STRCAT (rtos (sslength sset) 2 0) " Segments\n\n" "Layer is " lay "\n\n Area is  "  (RTOS AREAN 2 2)))
(princ)
Message 3 of 12
ronjonp
Here's a quick one:
(defun c:foo (/ _a a b l r s)
  ;; RJP » 2020-11-20
  (defun _a (o / r)
    (cond ((= 'real (type (setq r (vl-catch-all-apply 'vla-get-area (list o))))) r)
	  ;; ((= 'real (type (setq r (vl-catch-all-apply 'vlax-curve-getarea (list o))))) r)
  (if (setq s (ssget '((0 . "HATCH"))))
    (progn (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	     (setq l (cdr (assoc 8 (entget e))))
	     (if (setq a (_a (vlax-ename->vla-object e)))
	       (if (setq b (assoc l r))
		 (setq r (subst (cons l (+ (cdr b) a)) b r))
		 (setq r (cons (cons l a) r))
	       (print "Hatch does not have area!!")
	   (mapcar 'print (vl-sort r '(lambda (r j) (< (car r) (car j)))))
  (princ)
Message 4 of 12
trezatreza
Thanks for the responses
Please sir can you amend it :
1-remove the sign ( and "
2-That only two numbers appear after the comma (decimals)
3-Add total areas
(as pictured)
Message 5 of 12
pbejse
@trezatreza wrote:
(as pictured)
(as coded)
(defun C:Shoes ( / ss i e OArea data lay)
  (if (setq ss (ssget '((0 . "HATCH"))))
	    (progn
	    	(repeat (setq i (sslength ss))
		  (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
		  	(if (not (vl-catch-all-error-p
				   (setq OArea (vl-catch-all-apply 'vla-get-area (list e)))))
			  (setq data
			  	(if (setq f (assoc (setq lay (vla-get-layer e)) data))
				  	(subst (cons lay (+ (Cdr f) OArea)) f data)
				  	(cons (cons lay OArea) data)))
	      (foreach itm (append data (list (cons "Total Area..." (apply '+ (mapcar 'cdr data)))))
		(princ (strcat "\n" (Car itm) "......" (rtos (cdr itm) 2 2))))
(princ)
HTH
Message 6 of 12
trezatreza
Thank you very much, please change one last.
I added the code (prince "\ n ------------------------------------ in order to separate "total area" from the rest of "layer"
But also the layers are separate
	    (progn
			  (setq data
                         (princ "\n------------------------------------")
(princ)
Message 7 of 12
pbejse
(defun C:Shoes ( / PadRight ss i e OArea data lay)
(defun PadRight	(s1 s2 n c / str_)
  ((lambda (s1 s2)
     (repeat (- n (+ (strlen s1) (strlen s2)))
       (setq s1 (strcat s1 c))
     )(strcat "\n" s1 s2)
    (strcat s1 "") (strcat "" s2)
	    (progn
			  (setq data
	      (foreach itm data
		(princ (strcat (PadRight (Car itm)  (rtos (cdr itm) 2 2) 50 "."))))
	        (princ (strcat "\n--------------------------------------------------"
			(PadRight  "Total Area" (rtos (apply '+ (mapcar 'cdr data)) 2 2) 50 "."
(princ)
Command:  SHOES
Select objects: Specify opposite corner: 5 found
Select objects:
A-WALL-FULL-EXTR.............................22.91
A-AREA-OTLN.................................886.05
TRI_Space Class............................1288.60
Total Area.................................1553.27
Message 8 of 12
trezatreza
Please 🙏 🙏🙏 i want to change from 50 "." To “......” but it didn't work for me
  ((lambda (s1 s2)
	    (progn
			  (setq data
	      (foreach itm data
		(princ (strcat (PadRight (Car itm) "..........."  (rtos (cdr itm) 2 2)))))
			(PadRight  "Total Area.........." (rtos (apply '+ (mapcar 'cdr data)) 2 2)
(princ)
Message 9 of 12
pbejse
50 is the total length of the string
_$ (strlen "Total Area.................................1553.27")
50
Change 50 to a smaller number if you want shorter lines. Here's what 30 look like
A-WALL-FULL-EXTR.........22.91
A-AREA-OTLN.............886.05
TRI_Space Class........1288.60
Total Area.............1553.27
Message 10 of 12
trezatreza
Because if the layer name is long, the letters are attached to the numbers
Message 11 of 12
pbejse
This
to
(foreach itm data
(princ (strcat "\nTotal Area........." (rtos (apply '+ (mapcar 'cdr data)) 2 2)))
 HTH
Message 12 of 12
ronjonp
Here's another with prettier print results:
(defun c:foo (/ _a _pad a b l m r s x)
  ;; RJP » 2020-11-22
  (defun _a (o / r)
  (defun _pad (s n) (repeat n (setq s (strcat s "."))) (strcat s " "))
	   (setq m (+ 10 (apply 'max (mapcar 'strlen (mapcar 'car r)))))
	   (foreach x (append (vl-sort r '(lambda (r j) (< (car r) (car j))))
			      (list (cons "Total Area:" (apply '+ (mapcar 'cdr r))))
	     (princ (strcat "\n" (_pad (car x) (- m (strlen (car x)))) (rtos (cdr x) 2 2)))
  (princ)
Print to command line:
FOO
Select objects: Specify opposite corner: 15 found
Select objects:
0............... 3.32
Lay2............ 13.26
Layer1.......... 6.63
Layer3.......... 26.53
Total Area:..... 49.74
