calculate the area of a face of a 3dsolid
Juan-Emil_Saayman
Juan-Emil_Saayman
Hi
I want to be able to determine the surface area of a selected face of a 3dsolid. I've written a lisp routine, but I cant get get it to select the face that I want to calculate.
(defun c:area3dface ()
  (setq ss (ssget "_:L" '((0 . "3DSOLID"))))
  (if ss
    (progn
      (setq obj (ssname ss 0))
      (if (= (cdr (assoc 0 (entget obj))) "3DSOLID")
        (progn
          (setq pt (getpoint "\nSelect point on face to calculate area: "))
          (setq face (vlax-curve-getclosests (vlax-ename->vla-object obj) (vlax-3d-point pt) 1e-6))
          (if face
            (progn
              (setq area (vla-get-Area (vlax-ename->vla-object (car face))))
              (princ (strcat "\nArea of selected face: " (rtos area)))
            (princ "\nNo face selected.")
        (princ "\nSelected object is not a 3DSolid.")
    (princ "\nNo 3DSolid object selected.")
  (princ)
Please could somebody help me to fix this code.
yangguoshe
You can explode the 3D solid first to query the area of a single plane, and then “undo” back to  3dsolid
hmsilva
@Juan-Emil_Saayman to calculate the area of a face of a 3dsolid we can also use something like this
(defun c:demo (/ *error* area face lastent obj)
    (defun *error* (msg)
	(command-s "_.undo" "_back")
	(cond ((not msg))
	      ((member msg '("Function cancelled" "quit / exit abort")))
	      ((princ (strcat "\n** Error: " msg " ** ")))
	(princ)
    (command "_.undo" "_mark")
    (setq lastent (entlast))
    (setvar 'SUBOBJSELECTIONMODE 3)
    (command "SOLIDEDIT" "_F" "_C" pause "" "@" "@" "" "")
    (setq face (entlast))
    (setq obj (vlax-ename->vla-object face))
    (if	(and (not (eq lastent face))
	     (wcmatch (vla-get-objectname obj) "AcDbRegion")
	(progn
	    (setq area (vla-get-area obj))
	    (alert (strcat "Face area is:  " (rtos area 2 2)))
    (*error* nil)
    (princ)
Hope this helps,
Henrique
