cadex
cadex
cadex
Hello, everyone!
I am searching for a lisp for certain parameters to be exported to excel file from a .dwg/.dxf file. The perimeters of the entities selected that we need in excel file in a row of cells are
1)no of objects in the selected entities,
2)no of nodes in the entities
3)perimeter of the selected entities and
4) a statement of yes or no if the entities are closed polyline or open polyline.
I have been using tlen.lisp for perimeter,pedit command for closing polylines. I am not a novice in lisp creation so any help you can provide me would be highly appreciated!
Thanks in advance!
Moshe-A
@Anonymous  hi,
something like this?
enjoy
moshe
(defun c:dpl (/ ss elist csv^ fname f)
 (if (setq ss (ssget '((0 . "lwpolyline"))))
  (progn
   (foreach ename (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
    (setq elist (entget ename))
    (setq csv^ (cons
		 (list
		   (vlax-curve-getdistatparam ename (vlax-curve-getendparam ename))
		   (cdr (assoc '90 elist))
		   (cdr (assoc '70 elist))
		 csv^
    ); setq
   ); foreach
   (setq fname (strcat (getvar "dwgprefix") (vl-filename-base (getvar "dwgname")) ".csv"))
   (if (setq f (open fname "w"))
    (progn
     (write-line "length,nodes,close" f) ; header
     (foreach item (vl-sort csv^ '(lambda (a0 a1) (< (car a0) (car a1))))
      (write-line (strcat (rtos (car item) 2 2) "," (itoa (cadr item)) "," (if (= (caddr item) 1) "Yes" "No")) f)
     ); foreach
     (setq f (close f))
     (prompt (strcat "\ncreating " fname " file."))
    ); progn
   ); if
  ); progn
 ); if
 (princ)
Thank you,Moshe for the swift response.I am not getting.The Commandline
response after loading the dpl lisp was:
Specify entities»
Error: No function.
Moshe-A
@Anonymous  hi,
after loading the lisp you need to key in DPL on the command line to make it run.
moshe
Moshe-A
attached a minor update  😀
