c:wd_inplc_nd
c:wd_inplc_nd
c:wd_inplc_nd
when I Open *.dwg file from my project and use this command
(c:wd_inplc_nd (list 150.0 255.0 0.0) "2" "A2" nil nil 1 99 nil "V" (c:wd_find_sel_plc "1771-IAD") (list "" "aaa" "bbb" ))
in comandline, something is wrong. You can see the result in the picture (left PLC). When I use the command again everything is OK (right PLC).
This behavior is repeated every time when I close and open the drawing (new or the same one).
First wd_inplc_nd on the new open dwg file always return bad result.
All PLC in the database are drawn with the same error.
Can anyone replicate this error?
Does anyone know how to fix it?
Regards
Lukas
Software: AutoCAD Electrical 2015, version 12.0.55.0
Kent1Cooper
It's impossible to say without seeing the code that defines wd_inplc_nd, and possibly also wd_find_sel_plc.
Kent Cooper, AIA
hmsilva
Regards
Lukas
Hello Lucas and welcome to the Autodesk Community!
Unfortunately, few of us know the Electrical API, probably It will be easier to get some help at the AutoCAD Electrical General Discussion forum
Henrique
wd_inplc_nd and wd_find_sel_plc are LISP function from AutoCAD Electrical API
Lukas
Thank your for your advice. I send this post on the recommended forum.
hmsilva
You're welcome, Lucas!
Sorry, but I can not be much help, formerly, I've had access to the ACE API help files, but currently I dont have, so I can not assist... 😞
Henrique
