C: TEST function in 1 drawing only
iBlachu
iBlachu
How do I force my LISP function (eg C: TEST) to be defined only in the drawing in which I load it from the file?
martti.halminen
That is the standard behaviour of LOAD.
(unless you have that called somewhere where it gets called for each drawing.)
iBlachu
The problem is that when I load the LISP file (load "c: /test.lsp") and the file defines the following function:
(defun C:TEST() (alert "TEST:))
it is actually possible to use in the current drawing.
But the problem is that in other figures the abbreviation TEST (resulting from C: TEST) will be defined but without the function body (it won't work).
So how do you prevent C: TEST from being created in other drawings?
Kent1Cooper
@iBlachu wrote:
.... the problem is that in other figures the abbreviation TEST (resulting from C: TEST) will be defined but without the function body (it won't work).
It sounds, from your description, as though C:TEST is, in fact, not being created in other drawings, which is as desired, so what's the problem really?  [Doing likewise, if I include the missing closing quotation mark, does not create it in other drawings for me.]  But I confess I don't really understand what you mean by the red part above.
Kent Cooper, AIA
diagodose2009
You break the program "C:TEST.Lsp" into two pieces.
a)first. the main -programe name "pp_circle32pat_jc18lda.lsp"
b)second. You create the installer.lisp. If you hide the programe installer.lisp from other
  user/s  then anyone cannot run the "pp_circle32pat_jc18lda.lsp" outside the yourDrawing.dwg
The nickname for installer.lisp is "asm_lhc18lda.VLX"
But remember. if you wish and  run the application "pp_circle32pat_jc18lda.lsp",before,
   you must save the yourDrawing.dwg after you execute  "asm_lhc18lda.VLX".
If you want, saw the full-source of , you see the pp_circle32pat_jc12cws.lsp
The programe source-ascii.txt  named
is total-blocked , you cannot execute
"pp_circle32pat_jc18lda.lsp" without
asm_lhc18lda.VLX
** After you save yourDrawing.dwg,
you can execute "pp_circle32pat_jc18lda.lsp"
anytime inside yourDrawing.dwg, but you do not execute in other Drawing.dwg
diagodose2009
The  youDrawing.dwg must contain 3...10 x circles inside ModelSpace.
For this demo, I work 11hours, fixing the Error?s, but this demo, can be extended with Other.lisp
