Build list with the directions of the polylines
adaptacad
Message 1 of 28
adaptacad
There is a way to steal the direction a polyline is in accordance with the block, whether it is on the right, left, front or back and how many are in that direction.
and return a list like this ' ((2 "front") (0 "back") (2 "right") (1 "left"))
if someone helps me i will be very happy,
Thank you very much in advance!
Replies (27)
Message 2 of 28
Kent1Cooper
I'm not sure how to approach that, but clarify something:
According to the count, the red-circled diagonal line is apparently counted as going to the front, and the other diagonal one to the right.  But the red-circled one is closer in angle to the right than to the front.  What criteria determine what constitutes "front"-ward as opposed to "right"-ward?
Kent Cooper, AIA
Message 3 of 28
adaptacad
Thanks for the answer.
You're right, it was very confusing even for me.
it is not necessary to be very precise, the important thing is to indicate the direction and quantity.
so the understanding is better are basically these senses
return '((1 "N") (2 "E") (1 "NE") (1 "O"))
Message 4 of 28
doaiena
Here is my suggestion:
(pick a base point)
(foreach pline
(setq param (getParamAtPoint (getClosestPointTo base)))
(angle (getPointAtParam (fix param)) (getPointAtParam (+ (fix param) 1))
add to list etc...
Message 5 of 28
adaptacad
and how to do the comparison of the angles to know the direction ??
use the OR?
I still don't know how to do it!
Message 6 of 28
doaiena
This should get you started:
(defun c:test ( / ss pt ctr polyObj param ang lst)
(setq ss (ssget  '((0 . "LWPOLYLINE"))))
(setq pt (getpoint "\nPick a base point: "))
(if (and ss pt)
(progn
(setq ctr 0)
(repeat (sslength ss)
(setq polyObj (vlax-ename->vla-object (ssname ss ctr)))
(setq param (vlax-curve-getParamAtPoint polyObj (vlax-curve-getClosestPointTo polyObj pt)))
(setq ang (* 180.0 (/ (angle (vlax-curve-getPointAtParam polyObj (fix param)) (vlax-curve-getPointAtParam polyObj (+ (fix param) 1))) pi)))
(setq lst (cons ang lst))
(setq ctr (1+ ctr))
);repeat
(princ lst)
));if pt and ss
(princ)
);defun
Message 7 of 28
hak_vz
Different approach to the problem
(defun c:indira ( / deg_to_rad pt p1 p2 anglist dirlist ss i ret)
(defun deg_to_rad (deg)(* pi (/ deg 180.0)))
(setq pt (getpoint "\nSelect centerpoint >"))
(setq anglist (mapcar 'deg_to_rad '(45 135 225 315 45)))
(setq dirlist '("N" "O" "S" "E"))
(setq i 0)
(foreach dir dirlist
(setq p1 (polar pt (nth i anglist) 5))
(setq p2 (polar pt (nth (+ i 1) anglist) 5))
(setq ss(ssget "F" (list p1 p2)))
(if ss (setq n (sslength ss)) (setq n 0))
(setq ret (cons (list n dir) ret))
(setq i (+ i 1))
(reverse ret)
(setq anglist (mapcar 'deg_to_rad '(22.5 67.5 112.5 157.5 202.5 247.5 292.5 337.5 22.5)))
(setq dirlist '("NE" "N" "NO" "O" "SO" "S" "SE" "E"))
(setq i 0)
(setq i (+ i 1))
(reverse ret)
Miljenko Hatlak
Message 8 of 28
Kent1Cooper
@adaptacad wrote:
.... to indicate the direction and quantity.
But that should be determining angles not  in relation to absolute compass directions, but as directions relative to the rotation of the Block, if I understand the image in Message 1 correctly.
I see a problem with the nature of the Polylines.  The long horizontal above is one Polyline all the way across [though at least it has a vertex in the middle], so the same Polyline extends in more than one direction from the Block, and that is in its drawn  direction on one side but in the opposite  direction on the other side.  Likewise for the two diagonals, which are a single Polyline.  In other situations in the sample drawing, there are L-shaped 2-segment ones, and some that extend in only one direction with a single segment.  It would be difficult to find an approach that can account for all those possibilities, and would be much easier if all  of them were separate ones, with none continuing through at the middle.  I think @doaiena 's suggestion assumes they are separate, since it looks at each Polyline only once, not one segment at a time.  That can give only one result per Polyline, but you are looking for two results from many of your Polylines.
But even if they were all separate pieces, that approach could, I think, give opposite-direction results in some cases if any are drawn in the inward  direction, depending on the specific position of their inward end relative to the reference point or the Block.  If the nearest point of one drawn inward is at the downstream end, there will be no next parameter value, so the angle measurement will fail.  If the nearest point on it isn't at the very end, whether User-selected or based on the Block's insertion point, then the rounded-down parameter will be at the outward  end, and the angle will be measured in the opposite direction from the one intended.  This would be the case, for example, in the upper non-orthogonal situation if its lower-right Polyline were drawn from the outside in, instead of the way it is, and if the reference point is the Block insertion point.  @doaiena's suggestion asks the User for the reference point, but it would make sense to me to have that taken from the Block, since the Block needs to be selected anyway, if the angle determinations are to be relative to its rotation angle.
Also, are they always  Polylines, or might they sometimes be Lines, or something else?
Kent Cooper, AIA
Message 9 of 28
doaiena
In my post i just set up a general framework, upon which @adaptacad could expand. As you have already said, there are many more questions that need to be answered in order to provide a complete solution. The OP should jump in and post a very detailed explanation of what exactly needs to happen, including all the edge cases he could think of.
Message 10 of 28
adaptacad
@hak_vz  This was perfect !! thank you very much!
Message 11 of 28
adaptacad
(setq i 0)
(setq ss (ssget "F" (list p1 p2)))
(setq ent (ssname ss i))
(setq clr (cdr (assoc 62 (entget ent))))
(setq ret (list clr n dir))
;(setq ret (cons (list n dir) ret))
(setq i (+ i 1))
(reverse ret)
Why not add color ??
Message 12 of 28
hak_vz
You can do what ever you like. Just define what you would like.
Miljenko Hatlak
Message 13 of 28
Kent1Cooper
I'm wondering [without trying it]....  If a Line or Polyline or whatever lies exactly on  one of those break-point directions, such as 22.5°, won't it be touched by the Fence selection for two  of the octants, and therefore be counted twice?  Maybe you would want it counted for both octants, but if not, some criteria would be needed for which of them to include it in.
[Also, I don't know the typical circumstances, but that 5 for the distance from the center in setting p1 & p2 requires that all objects to be found must come at least to within 5 drawing units of the center at their inner end, and extend at least to 5 drawing units away at their outer end.  Would that always be the case?]
Kent Cooper, AIA
Message 14 of 28
adaptacad
It's perfect like you did.
I just don't understand how I can add color to the list.
what's wrong with my editing?
Message 15 of 28
adaptacad
@Kent1Cooper  I don't understand what you mean, can you give me an example ??
in all the tests I did the @hak_vz routine) it worked perfectly.
Message 16 of 28
Kent1Cooper
@adaptacad wrote:
@Kent1Cooper  I don't understand what you mean, can you give me an example ?? ....
When I do this:
yellow-to-green should be the Fence for the NorthEast octant, and it should find both  the 22.5° and 67.5° lines.  And green-to-cyan should be the Fence for the North octant, and it should find both  the 67.5° and 112.5° lines.  Using the indira command on them returns this:
((0 "NE") (1 "N") (1 "NO") (0 "O") (0 "SO") (0 "S") (0 "SE") (1 "E"))
It's seeing all three lines, only once each, but note that two of them [N, NO] are being counted in the octant that is counterclockwise  from the line's direction, but one [E] is being counted in the octant that is clockwise  from the line's direction.
I assume the fact that none of them is being counted in two  adjacent octants is a rounding issue in the degrees-to-radians calculations, and the Fence endpoints are not always precisely on the octant break directions, but these lines are.  I tried it on this:
with all  of the octant-dividing directions, and this was returned:
((0 "NE") (2 "N") (0 "NO") (2 "O") (0 "SO") (2 "S") (1 "SE") (1 "E"))
Some octants are not "given" any lines, some are given 1, and some 2.  It may not be that some of those lines are being counted twice in two adjacent octants, because two of the Fences in the selections touch them [which is what I suspected might happen in my previous Reply], but at least some Fences are seeing the lines at both ends of them, and some are not seeing the line at either end.
Kent Cooper, AIA
Message 17 of 28
adaptacad
Wow! I am always surprised by the technical look of you !!!
This is really a @Kent1Cooper  problem and I haven't checked it out!
Message 18 of 28
adaptacad
but at the moment I don't understand how to get the name of the entity to get the color of the polyline and add to the list.
Message 19 of 28
Kent1Cooper
I tried a different approach to the angle calculations:
(setq anglist '(1 3 5 7 9 11 13 15 1))
(setq p1 (polar pt (* pi (/ (nth i anglist) 8.0)) 5))
(setq p2 (polar pt (* pi (/ (nth (+ i 1) anglist) 8.0)) 5))
and got this result [different varieties of the same problem]:
((1 "NE") (0 "N") (1 "NO") (1 "O") (2 "SO") (0 "S") (2 "SE") (1 "E"))
Kent Cooper, AIA
Message 20 of 28
adaptacad
@Kent1Cooper  The chance of this influencing is very small !! I believe it will be in very, very rare cases.
