BUG: Naming a Layout with #
Try this...
Name a Layout with the number sign in it, i.e. "RFI #077", and try the
following code to create a selection set of all block with certain name. You
will need to substitute the "$i_*" with your block name specification. It
will return nil even though these blocks exist.
(setq ss1 (ssget "x" (list (cons 0 "insert") (cons 2 "$i_*")(cons 410
(getvar "ctab")))))
Now rename your layout to exclude the number sign, i.e. "RFI 077", and try
the code again and it will return a selection set.
Jim Dee
Hi Jim,
This is due to Autocad allowing the special symbols (that (wcmatch) uses as
wildcards) to be used in Layout names. And although we'd call it a bug, they
seem to have chosen to overlook it. This can be done with layers, too, btw.
There was a discussion about this anomoly sometime ago.
Jeff
"Jim Dee" wrote in message
news:4981597@discussion.autodesk.com...
Try this...
(getvar "ctab")))))
Jim Dee
Jim,
Have you tried to escape the pound sign?
(setq ctab (getvar "ctab"))
"test#"
(setq ctab (escChrs ctab "#"))
"test`#"
(ssget "x" (list (cons 0 "insert") (cons 2 "test")(cons 410 ctab)))
; Jason Piercey . September 10th, 2003
; function to return a list of single character
; strings from the characters within a stirng.
; {string] - string to 'characterize'
; return: list of strings
; examples:
; (strChr "Abc") -> ("A" "b" c")
; (strChr "A b c") -> ("A" " " "b" " " c")
; revised: 02/02/04 added function call
(defun strChr (string)
(mapcar
(function
(lambda (x)
(vl-list->string (list x))
(vl-string->list string)
; function to return a string with escaped characters
; [string] - string, to search
; [escape] - string, characters to escape
; example:
; (escChrs "abc" "a") -> "`abc"
; (escChrs "abca" "a") -> "`abc`a"
; file dependencies: strChr.lsp
(defun escChrs (string escape)
(setq string (strChr string))
(setq escape (strChr escape))
(apply
'strcat
(foreach x string
(if (vl-position x escape)
(setq string (subst (strcat "`" x) x string)))
string
Autodesk Discussion Group Facilitator
Try this...
(getvar "ctab")))))
Jim Dee
