Bubbleinc.lsp is not working in AMEP 2014
Gartner13205
Gartner13205
This is a great incremental tagging routine but it has stopped working properly for me now that I am using AutoCAD MEP 2014.  It worked in AutoCAD MEP 2012 but now it will not increment.  I have created the BUBBLE multi leader style as required and it works right up until it is supposed to automatically number the tag.
Thanks for any help you can offer.
CADaSchtroumpf
Perhaps...
Put system variable ATTDIA to 0 before using your code , or make this in the code.
Gartner13205
That worked!  Thank you so much.  I would like to put this in the code but I am code-challenged.  Would you be able to tell me where to put it and exactly what I should type?
Thanks again, this is fabulous!
CADaSchtroumpf
Quickly,
(defun c:BI (/ *error* _toLayer style layer cmd sty attd pt lst)
  ;; Bubble Increment (MLeader style required)
  ;; Alan J. Thompson, 12.04.11
  (setq style "BUBBLE" ; MLeader style (with single attribute block)
        layer nil ; layer to place MLeader objects on (optional, nil for current layer)
  (vl-load-com)
  (defun *error* (msg)
    (and cmd (setvar 'CMDECHO cmd))
    (and sty (setvar 'CMLEADERSTYLE sty))
    (and attd (setvar 'ATTDIA attd))
    (and *AcadDoc* (vla-endundomark *AcadDoc*))
    (if (and msg (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*QUIT*,")))
      (princ (strcat "\nError: " msg))
  (setq _toLayer
         (eval
           (list
             'lambda
             '(e / d)
             (if (and layer (snvalid layer))
               '(entupd
                 (cdr (assoc -1 (entmod (subst (cons 8 layer) (assoc 8 (setq d (entget e))) d))))
  (vla-startundomark
    (cond (*AcadDoc*)
          ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
  (setq cmd (getvar 'CMDECHO)
        sty (getvar 'CMLEADERSTYLE)
        attd (getvar 'ATTDIA)
  (setvar 'CMDECHO 0)
  (setvar 'ATTDIA 0)
  (cond ((not (vl-catch-all-error-p (vl-catch-all-apply 'setvar (list 'CMLEADERSTYLE style))))
         (initget 6)
         (setq *BI:Inc* (cond ((getint (strcat "\nSpecify starting number <"
                                               (itoa (cond (*BI:Inc*)
                                                           ((setq *BI:Inc* 1))
                              (*BI:Inc*)
         (while (if lst
                  (progn (initget "Undo") (setq pt (getpoint "\nSpecify starting point [Undo]: ")))
                  (setq pt (getpoint "\nSpecify starting point: "))
           (if (eq pt "Undo")
             (progn (entdel (car lst)) (setq *BI:Inc* (1- *BI:Inc*)) (setq lst (cdr lst)))
             (progn
               (princ "\nSpecify other point: ")
               (vl-cmdf "_.mleader" "_non" pt PAUSE)
               (if (eq (logand 1 (getvar 'CMDACTIVE)) 1)
                 (progn (vl-cmdf *BI:Inc*)
                        (setq *BI:Inc* (1+ *BI:Inc*)
                              lst      (cons (entlast) lst)
                        (_toLayer (car lst))
        ((alert (strcat style " multileader style not loaded!")))
  (*error* nil)
  (princ)
Gartner13205
Perfect!  You have saved me big time.
Thank you for your help and expertise!
