Break poly line and insert spline
eng_mohamedmustafa
Message 1 of 8
eng_mohamedmustafa
Hi all
I need help ... I want a lisp to select all polylines on my drawing at the same time ... the lisp do breaks at any intersection one of them ( i see lisps that break both polylines) and insert at break ends spline (block) as shown in photo
Replies (7)
Message 2 of 8
ВeekeeCZ
We are here to help you learn to program. Not help you to get a program.
Have ever even tried to write something? It does not look like that because the first thing that we need is a DWG drawing, not a screenshot.
Message 3 of 8
eng_mohamedmustafa
i have this lisp ...
;;;=======================[ BreakObjects.lsp ]==============================
;;; Author: Copyright© 2006-2008 Charles Alan Butler
;;; Contact @ www.TheSwamp.org
;;; Version: 2.1 Nov. 20,2008
;;; Purpose: Break All selected objects
;;; permitted objects are lines, lwplines, plines, splines,
;;; ellipse, circles & arcs
;;; Function c:MyBreak - DCL for selecting the routines
;;; Function c:BreakAll - Break all objects selected with each other
;;; Function c:BreakwObject - Break many objects with a single object
;;; Function c:BreakObject - Break a single object with other objects
;;; Function c:BreakWith - Break selected objects with other selected objects
;;; Function c:BreakTouching - Break objects touching selected objects
;;; Function c:BreakSelected - Break selected objects with any objects that touch it
;;; Revision 1.8 Added Option for Break Gap greater than zero
;;; NEW r1.9 c:BreakWlayer - Break objects with objects on a layer
;;; NEW r1.9 c:BreakWithTouching - Break touching objects with selected objects
;;; Revision 2.0 Fixed a bug when point to break is at the end of object
;;; Revision 2.1 Fixed another bug when point to break is at the end of object
;;; Function break_with - main break function called by all others and
;;; returns a list of new enames, see c:BreakAll
;;; for an example of using the return list
;;; Requirements: objects must have the same z-value
;;; Restrictions: Does not Break objects on locked layers
;;; Returns: none
;;; THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED ;
;;; WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR ;
;;; PURPOSE AND OF MERCHANTABILITY ARE HEREBY DISCLAIMED. ;
;;; You are hereby granted permission to use, copy and modify this ;
;;; software without charge, provided you do so exclusively for ;
;;; your own use or for use by others in your organization in the ;
;;; performance of their normal duties, and provided further that ;
;;; the above copyright notice appears in all copies and both that ;
;;; copyright notice and the limited warranty and restricted rights ;
;;; notice below appear in all supporting documentation. ;
;; M A I N S U B R O U T I N E
(defun break_with (ss2brk ss2brkwith self Gap / cmd intpts lst masterlist ss ssobjs
onlockedlayer ssget->vla-list list->3pair GetNewEntities oc
get_interpts break_obj GetLastEnt LastEntInDatabase ss2brkwithList
;; ss2brk selection set to break
;; ss2brkwith selection set to use as break points
;; self when true will allow an object to break itself
;; note that plined will break at each vertex
;; return list of enames of new objects
(vl-load-com)
(princ "\nCalculating Break Points, Please Wait.\n")
;; S U B F U N C T I O N S
;; return T if entity is on a locked layer
(defun onlockedlayer (ename / entlst)
(setq entlst (tblsearch "LAYER" (cdr (assoc 8 (entget ename)))))
(= 4 (logand 4 (cdr (assoc 70 entlst))))
;; return a list of objects from a selection set
;| (defun ssget->vla-list (ss)
(mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss ))))
(defun ssget->vla-list (ss / i ename allobj) ; this is faster, changed in ver 1.7
(setq i -1)
(while (setq ename (ssname ss (setq i (1+ i))))
(setq allobj (cons (vlax-ename->vla-object ename) allobj))
allobj
;; return a list of lists grouped by 3 from a flat list
(defun list->3pair (old / new)
(while (setq new (cons (list (car old) (cadr old) (caddr old)) new)
old (cdddr old)))
(reverse new)
;; return a list of intersect points
(defun get_interpts (obj1 obj2 / iplist)
(if (not (vl-catch-all-error-p
(setq iplist (vl-catch-all-apply
'vlax-safearray->list
(list
(vlax-variant-value
(vla-intersectwith obj1 obj2 acextendnone)
iplist
;; Break entity at break points in list
;; New as per version 1.8 [BrkGap] --- This subroutine has been re-written
;; Loop through the break points breaking the entity
;; If the entity is not a closed entity then a new object is created
;; This object is added to a list. When break points don't fall on the current
;; entity the list of new entities are searched to locate the entity that the
;; point is on so it can be broken.
;; "Break with a Gap" has been added to this routine. The problem faced with
;; this method is that sections to be removed may lap if the break points are
;; too close to each other. The solution is to create a list of break point pairs
;; representing the gap to be removed and test to see if there i an overlap. If
;; there is then merge the break point pairs into one large gap. This way the
;; points will always fall on an object with one exception. If the gap is too near
;; the end of an object one break point will be off the end and therefore that
;; point will need to be replaced with the end point.
;; NOTE: in ACAD2000 the (vlax-curve-getdistatpoint function has proven unreliable
;; so I have used (vlax-curve-getdistatparam in most cases
(defun break_obj (ent brkptlst BrkGap / brkobjlst en enttype maxparam closedobj
minparam obj obj2break p1param p2param brkpt2 dlst idx brkptS
brkptE brkpt result GapFlg result ignore dist tmppt
#ofpts 2gap enddist lastent obj2break stdist
(or BrkGap (setq BrkGap 0.0)) ; default to 0
(setq BrkGap (/ BrkGap 2.0)) ; if Gap use 1/2 per side of break point
(setq obj2break ent
brkobjlst (list ent)
enttype (cdr (assoc 0 (entget ent)))
GapFlg (not (zerop BrkGap)) ; gap > 0
closedobj (vlax-curve-isclosed obj2break)
;; when zero gap no need to break at end points
(if (zerop Brkgap)
(setq spt (vlax-curve-getstartpoint ent)
ept (vlax-curve-getendpoint ent)
brkptlst (vl-remove-if '(lambda(x) (or (< (distance x spt) 0.0001)
(< (distance x ept) 0.0001)))
brkptlst)
(if brkptlst
(progn
;; sort break points based on the distance along the break object
;; get distance to break point, catch error if pt is off end
;; ver 2.0 fix - added COND to fix break point is at the end of a
;; line which is not a valid break but does no harm
(setq brkptlst (mapcar '(lambda(x) (list x (vlax-curve-getdistatparam obj2break
;; ver 2.0 fix
(cond ((vlax-curve-getparamatpoint obj2break x))
(vlax-curve-getclosestpointto obj2break x))))))
) brkptlst))
;; sort primary list on distance
(setq brkptlst (vl-sort brkptlst '(lambda (a1 a2) (< (cadr a1) (cadr a2)))))
(if GapFlg ; gap > 0
;; Brkptlst starts as the break point and then a list of pairs of points
;; is creates as the break points
(progn
;; create a list of list of break points
;; ((idx# stpoint distance)(idx# endpoint distance)...)
(setq idx 0)
(foreach brkpt brkptlst
;; create start break point, then create end break point
;; ((idx# startpoint distance)(idx# endpoint distance)...)
(setq dist (cadr brkpt)) ; distance to center of gap
;; subtract gap to get start point of break gap
(cond
((and (minusp (setq stDist (- dist BrkGap))) closedobj )
(setq stdist (+ (vlax-curve-getdistatparam obj2break
(vlax-curve-getendparam obj2break)) stDist))
(setq dlst (cons (list idx
(vlax-curve-getpointatparam obj2break
(vlax-curve-getparamatdist obj2break stDist))
stDist) dlst))
((minusp stDist) ; off start of object so get startpoint
(setq dlst (cons (list idx (vlax-curve-getstartpoint obj2break) 0.0) dlst))
(t
stDist) dlst))
;; add gap to get end point of break gap
(cond
((and (> (setq stDist (+ dist BrkGap))
(setq endDist (vlax-curve-getdistatparam obj2break
(vlax-curve-getendparam obj2break)))) closedobj )
(setq stdist (- stDist endDist))
stDist) dlst))
((> stDist endDist) ; off end of object so get endpoint
endDist) dlst))
(t
stDist) dlst))
(setq idx (1+ IDX))
) ; foreach brkpt brkptlst
(setq dlst (reverse dlst))
;; remove the points of the gap segments that overlap
(setq idx -1
2gap (* BrkGap 2)
#ofPts (length Brkptlst)
(while (<= (setq idx (1+ idx)) #ofPts)
(cond
((null result) ; 1st time through
(setq result (list (car dlst)) ; get first start point
result (cons (nth (1+(* idx 2)) dlst) result))
((= idx #ofPts) ; last pass, check for wrap
(if (and closedobj (> #ofPts 1)
(<= (+(- (vlax-curve-getdistatparam obj2break
(cadr (last BrkPtLst))) (cadar BrkPtLst)) 2Gap))
(progn
(if (zerop (rem (length result) 2))
(setq result (cdr result)) ; remove the last end point
;; ignore previous endpoint and present start point
(setq result (cons (cadr (reverse result)) result) ; get last end point
result (cdr (reverse result))
result (reverse (cdr result)))
;; Break Gap Overlaps
((< (cadr (nth idx Brkptlst)) (+ (cadr (nth (1- idx) Brkptlst)) 2Gap))
(setq result (cons (nth (1+(* idx 2)) dlst) result)) ; get present end point
;; Break Gap does Not Overlap previous point
(t
(setq result (cons (nth (* idx 2) dlst) result)) ; get this start point
(setq result (cons (nth (1+(* idx 2)) dlst) result)) ; get this end point
) ; end cond stmt
) ; while
;; setup brkptlst with pair of break pts ((p1 p2)(p3 p4)...)
;; one of the pair of points will be on the object that
;; needs to be broken
(setq dlst (reverse result)
brkptlst nil)
(while dlst ; grab the points only
(setq brkptlst (cons (list (cadar dlst)(cadadr dlst)) brkptlst)
dlst (cddr dlst))
;; (if (equal a ent) (princ)) ; debug CAB -------------
(foreach brkpt (reverse brkptlst)
(setq brkptS (car brkpt)
brkptE (cadr brkpt))
brkptE brkptS)
;; get last entity created via break in case multiple breaks
(if brkobjlst
(progn
(setq tmppt brkptS) ; use only one of the pair of breakpoints
;; if pt not on object x, switch objects
(if (not (numberp (vl-catch-all-apply
'vlax-curve-getdistatpoint (list obj2break tmppt))))
(progn ; find the one that pt is on
(setq idx (length brkobjlst))
(while (and (not (minusp (setq idx (1- idx))))
(setq obj (nth idx brkobjlst))
(if (numberp (vl-catch-all-apply
'vlax-curve-getdistatpoint (list obj tmppt)))
(null (setq obj2break obj)) ; switch objects, null causes exit
t
;| ;; ver 2.0 fix - removed this code as there are cases where the break point
;; is at the end of a line which is not a valid break but does no harm
(if (and brkobjlst idx (minusp idx)
(null (alert (strcat "Error - point not on object"
"\nPlease report this error to"
"\n CAB at TheSwamp.org"))))
(exit)
;; (if (equal (if (null a)(setq a (car(entsel"\nTest Ent"))) a) ent) (princ)) ; debug CAB -------------
;; Handle any objects that can not be used with the Break Command
;; using one point, gap of 0.000001 is used
(setq closedobj (vlax-curve-isclosed obj2break))
(if closedobj
(progn ; need to break a closed object
(setq brkpt2 (vlax-curve-getPointAtDist obj2break
(- (vlax-curve-getDistAtPoint obj2break brkptE) 0.00001)))
(command "._break" obj2break "_non" (trans brkpt2 0 1)
"_non" (trans brkptE 0 1))
(and (= "CIRCLE" enttype) (setq enttype "ARC"))
(setq BrkptE brkpt2)
;; single breakpoint ----------------------------------------------------
;|(if (and closedobj ; problems with ACAD200 & this code
(not (setq brkptE (vlax-curve-getPointAtDist obj2break
(+ (vlax-curve-getDistAtPoint obj2break brkptS) 0.00001))))
(- (vlax-curve-getDistAtPoint obj2break brkptS) 0.00001)))
(if (and closedobj
;;(vlax-curve-getparamatpoint obj2break brkpts)) 0.00001))))
;; ver 2.0 fix
(cond ((vlax-curve-getparamatpoint obj2break brkpts))
(vlax-curve-getclosestpointto obj2break brkpts))))) 0.00001)))))
;; ver 2.0 fix
) ; endif
;; (if (null brkptE) (princ)) ; debug
(setq LastEnt (GetLastEnt))
(command "._break" obj2break "_non" (trans brkptS 0 1) "_non" (trans brkptE 0 1))
(and *BrkVerbose* (princ (setq *brkcnt* (1+ *brkcnt*))) (princ "\r"))
(if (and (not closedobj) ; new object was created
(not (equal LastEnt (entlast))))
(setq brkobjlst (cons (entlast) brkobjlst))
) ; endif brkptlst
) ; defun break_obj
;; CAB - get last entity in datatbase
(defun GetLastEnt ( / ename result )
(if (setq result (entlast))
(while (setq ename (entnext result))
(setq result ename)
result
;; CAB - return a list of new enames
(defun GetNewEntities (ename / new)
(cond
((null ename) (alert "Ename nil"))
((eq 'ENAME (type ename))
(while (setq ename (entnext ename))
(if (entget ename) (setq new (cons ename new)))
((alert "Ename wrong type."))
new
;; S T A R T S U B R O U T I N E H E R E
(setq LastEntInDatabase (GetLastEnt))
(if (and ss2brk ss2brkwith)
(progn
(setq oc 0
ss2brkwithList (ssget->vla-list ss2brkwith))
(if (> (* (sslength ss2brk)(length ss2brkwithList)) 5000)
(setq *BrkVerbose* t)
(and *BrkVerbose*
(princ (strcat "Objects to be Checked: "
(itoa (* (sslength ss2brk)(length ss2brkwithList))) "\n")))
;; CREATE a list of entity & it's break points
(foreach obj (ssget->vla-list ss2brk) ; check each object in ss2brk
(if (not (onlockedlayer (vlax-vla-object->ename obj)))
(progn
(setq lst nil)
;; check for break pts with other objects in ss2brkwith
(foreach intobj ss2brkwithList
(if (and (or self (not (equal obj intobj)))
(setq intpts (get_interpts obj intobj))
(setq lst (append (list->3pair intpts) lst)) ; entity w/ break points
(and *BrkVerbose* (princ (strcat "Objects Checked: " (itoa (setq oc (1+ oc))) "\r")))
(if lst
(setq masterlist (cons (cons (vlax-vla-object->ename obj) lst) masterlist))
(and *BrkVerbose* (princ "\nBreaking Objects.\n"))
(setq *brkcnt* 0) ; break counter
;; masterlist = ((ent brkpts)(ent brkpts)...)
(if masterlist
(foreach obj2brk masterlist
(break_obj (car obj2brk) (cdr obj2brk) Gap)
(and (zerop *brkcnt*) (princ "\nNone to be broken."))
(setq *BrkVerbose* nil)
(GetNewEntities LastEntInDatabase) ; return list of enames of new objects
;; E N D O F M A I N S U B R O U T I N E
;; M A I N S U B F U N C T I O N S
;; Redraw ss with mode
(defun ssredraw (ss mode / i num)
(setq i -1)
(redraw (ssname ss i) mode)
;; get all objects touching entities in the sscross
;; limited obj types to "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"
;; returns a list of enames
(defun gettouching (sscros / ss lst lstb lstc objl)
(and
(setq lstb (vl-remove-if 'listp (mapcar 'cadr (ssnamex sscros)))
objl (mapcar 'vlax-ename->vla-object lstb)
(setq
ss (ssget "_A" (list (cons 0 "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")
(cons 410 (getvar "ctab"))))
(setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
(setq lst (mapcar 'vlax-ename->vla-object lst))
(mapcar
'(lambda (x)
(mapcar
'(lambda (y)
(if (not
(vl-catch-all-apply
'(lambda ()
(vlax-safearray->list
(vlax-variant-value
(vla-intersectwith y x acextendnone)
(setq lstc (cons (vlax-vla-object->ename x) lstc))
) objl)
) lst)
lstc
;; E N D M A I N F U N C T I O N S
;; Break all objects selected with each other
(defun c:BreakAll (/ cmd ss NewEnts AllEnts tmp)
(command "_.undo" "_begin")
(setq cmd (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
(or Bgap (setq Bgap 0)) ; default
(initget 4) ; no negative numbers
(if (setq tmp (getdist (strcat "\nEnter Break Gap.<"(rtos Bgap)"> ")))
(setq Bgap tmp)
;; get objects to break
(prompt "\nSelect objects to break with each other & press enter: ")
(if (setq ss (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(setq NewEnts (Break_with ss ss nil Bgap) ; ss2break ss2breakwith (flag nil = not to break with self)
; AllEnts (append NewEnts (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
(setvar "CMDECHO" cmd)
(command "_.undo" "_end")
(princ)
;; Break a single object with other objects
(defun c:BreakObject (/ cmd ss1 ss2 tmp)
(setq Bgap tmp)
(prompt "\nSelect single object to break: ")
(if (and (setq ss1 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(not (redraw (ssname ss1 0) 3))
(not (prompt "\n*** Select object(s) to break with & press enter: ***"))
(setq ss2 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(not (redraw (ssname ss1 0) 4)))
(Break_with ss1 ss2 nil Bgap) ; ss2break ss2breakwith (flag nil = not to break with self)
(princ)
;; Break many objects with a single object
(defun c:BreakWobject (/ cmd ss1 ss2 tmp)
(setq Bgap tmp)
(prompt "\nSelect object(s) to break & press enter: ")
(if (and (setq ss1 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(not (ssredraw ss1 3))
(not (prompt "\n*** Select single object to break with: ***"))
(setq ss2 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(not (ssredraw ss1 4))
(break_with ss1 ss2 nil Bgap) ; ss1break ss2breakwith (flag nil = not to break with self)
(princ)
;; Break objects with objects on a layer
;; New 08/01/2008
(defun c:BreakWlayer (/ cmd ss1 ss2 tmp lay)
(setq Bgap tmp)
(prompt "\n*** Select single object for break layer: ***")
(if (and (setq ss2 (ssget "+.:E:S" '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(setq lay (assoc 8 (entget (ssname ss2 0))))
(setq ss2 (ssget "_X" (list
'(0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE")
lay (cons 410 (getvar "ctab")))))
(not (prompt "\nSelect object(s) to break & press enter: "))
(setq ss1 (ssget (list
(cons 8 (strcat "~" (cdr lay))))))
(princ)
;; Break selected objects with other selected objects
(defun c:BreakWith (/ cmd ss1 ss2 tmp)
(setq Bgap tmp)
(prompt "\nBreak selected objects with other selected objects.")
(princ)
;; Break objects touching selected objects
(defun c:BreakTouching (/ cmd ss1 ss2 tmp)
(setq ss1 (ssadd))
(setq Bgap tmp)
(prompt "\nBreak objects touching selected objects.")
(if (and (not (prompt "\nSelect object(s) to break & press enter: "))
(mapcar '(lambda (x) (ssadd x ss1)) (gettouching ss2))
(princ)
;; Break touching objects with selected objects
;; New 08/01/2008
(defun c:BreakWithTouching (/ cmd ss1 ss2 tmp)
(setq ss1 (ssadd))
(setq Bgap tmp)
(prompt "\nSelect object(s) to break with & press enter: ")
(if (and (setq ss2 (ssget '((0 . "LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE"))))
(setq tlst (gettouching ss2))
(progn
(setq tlst (vl-remove-if '(lambda (x)(ssmemb x ss2)) tlst)) ; remove if in picked ss
(mapcar '(lambda (x) (ssadd x ss1)) tlst) ; convert to a selection set
(princ)
;; Break selected objects with any objects that touch it
(defun c:BreakSelected (/ cmd ss1 ss2 tmp)
(setq ss1 (ssadd))
(setq Bgap tmp)
(prompt "\nBreak selected objects with any objects that touch it.")
(if (and (not (prompt "\nSelect object(s) to break with touching & press enter: "))
(break_with ss2 ss1 nil Bgap)
; ss2break ss1breakwith (flag nil = not to break with self)
(princ)
;; Function to create a dcl support file if it
;; does not exist
;; Usage : (create_dcl "file name")
;; Returns : T if successful else nil
(defun create_Breakdcl (fname / acadfn dcl-rev-check)
;; check revision date Routine
(defun dcl-rev-check (fn / rvdate ln lp)
;; revision flag must match exactly and must
;; begin with //
(setq rvflag "// Revision Control 05/12/2008@14:11" )
(if (setq fn (findfile fn))
(progn ; check rev date
(setq lp 5) ; read 4 lines
(setq fn (open fn "r")) ; open file for reading
(while (> (setq lp (1- lp)) 0)
(setq ln (read-line fn)) ; get a line from file
(if (vl-string-search rvflag ln)
(setq lp 0)
(close fn) ; close the open file handle
(if (= lp -1)
nil ; no new dcl needed
t ; flag to create new file
(if (null(wcmatch (strcase fname) "*`.DCL"))
(setq fname (strcat fname ".DCL"))
(if (dcl-rev-check fname)
;; create dcl file in same directory as ACAD.PAT
(progn
(setq acadfn (findfile "ACAD.PAT")
fn (strcat (substr acadfn 1 (- (strlen acadfn) 8))fname)
fn (open fn "w")
(foreach x (list
"// WARNING file will be recreated if you change the next line"
rvflag
"//BreakAll.DCL"
"BreakDCL : dialog { label = \"[ Break All or Some by CAB v1.8 ]\";"
" : text { label = \"--=< Select type of Break Function needed >=--\"; "
" key = \"tm\"; alignment = centered; fixed_width = true;}"
" spacer_1;"
" : button { key = \"b1\"; mnemonic = \"T\"; alignment = centered;"
" label = \"Break all objects selected with each other\";} "
" : button { key = \"b2\"; mnemonic = \"T\"; alignment = centered;"
" label = \"Break selected objects with other selected objects\";}"
" : button { key = \"b3\"; mnemonic = \"T\"; alignment = centered;"
" label = \" Break selected objects with any objects that touch it\";}"
" spacer_1;"
" : row { spacer_0;"
" : edit_box {key = \"gap\" ; width = 8; mnemonic = \"G\"; label = \"Gap\"; fixed_width = true;}"
" : button { label = \"Help\"; key = \"help\"; mnemonic = \"H\"; fixed_width = true;} "
" cancel_button;"
" spacer_0;"
) ; endlist
(princ x fn)
(write-line "" fn)
) ; end foreach
(close fn)
(setq acadfn nil)
(alert (strcat "\nDCL file created, please restart the routine"
"\n again if an error occures."))
t ; return True, file created
t ; return True, file found
) ; end defun
;; BreakAll Dialog Routine
(defun c:MyBreak(/ dclfile dcl# RunDCL BreakHelp cmd txt2num)
;; return number or nil
(defun txt2num (txt / num)
(if txt
(or (setq num (distof txt 5))
(setq num (distof txt 2))
(setq num (distof txt 1))
(setq num (distof txt 4))
(setq num (distof txt 3))
(if (numberp num)
num
(defun mydonedialog (flag)
(setq DCLgap (txt2num (get_tile "gap")))
(done_dialog flag)
(defun RunDCL (/ action)
(or DCLgap (setq DCLgap 0)) ; error trap value
(action_tile "b1" "(mydonedialog 1)")
(action_tile "b2" "(mydonedialog 2)")
(action_tile "b3" "(mydonedialog 3)")
(action_tile "gap" "(setq DCLgap (txt2num value$))")
(set_tile "gap" (rtos DCLgap))
(action_tile "help" "(BreakHelp)")
(action_tile "cancel" "(done_dialog 0)")
(setq action (start_dialog))
(setq DCLgap (max DCLgap 0)) ; nu negative numbers
(cond
((= action 1) ; BreakAll
(setq NewEnts (Break_with ss ss nil DCLgap) ; ss2break ss2breakwith (flag nil = not to break with self)
(princ)
((= action 2) ; BreakWith
(break_with ss1 ss2 nil DCLgap) ; ss1break ss2breakwith (flag nil = not to break with self)
((= action 3) ; BreakSelected
(setq ss1 (ssadd))
(break_with ss2 ss1 nil DCLgap) ; ss2break ss1breakwith (flag nil = not to break with self)
(defun BreakHelp ()
(alert
(strcat
"BreakAll.lsp (c) 2007-2008 Charles Alan Butler\n\n"
"This LISP routine will break objects based on the routine you select.\n"
"It will not break objects on locked layers and objects must have the same z-value.\n"
"Object types are limited to LINE,ARC,SPLINE,LWPOLYLINE,POLYLINE,CIRCLE,ELLIPSE\n"
"BreakAll - Break all objects selected with each other\n"
"BreakwObject - Break many objects with a single object\n"
"BreakObject - Break a single object with many objects \n"
"BreakWith - Break selected objects with other selected objects\n"
"BreakTouching - Break objects touching selected objects\n"
"BreakSelected - Break selected objects with any objects that touch it\n"
" The Gap distance is the total opening created.\n"
"You may run each routine by entering the function name at the command line.\n"
"For updates & comments contact Charles Alan Butler AKA CAB at TheSwamp.org.\n")
;; Start of Routine
(vl-load-com)
(setq dclfile "BreakAll.dcl")
(cond
((not (create_Breakdcl dclfile))
(prompt (strcat "\nCannot create " dclfile "."))
((< (setq dcl# (load_dialog dclfile)) 0)
(prompt (strcat "\nCannot load " dclfile "."))
((not (new_dialog "BreakDCL" dcl#))
(prompt (strcat "\nProblem with " dclfile "."))
((RunDCL)) ; No DCL problems: fire it up
(and cmd (setvar "CMDECHO" cmd))
(princ)
(prompt "Break routines loaded, Enter Mybreak to run.")
(princ)
;; E n d O f F i l e I f y o u A r e H e r e
but when i choose all drawing it breaks all polylines ... i want to break one of them and insert block that showed in photo
Message 4 of 8
Kent1Cooper
@eng_mohamedmustafa wrote:
... I want a lisp to select all polylines on my drawing at the same time ... do breaks at any intersection one of them ... and insert at break ends ... (block) ....
The first enormous difficulty in the situation you describe would be the question of how AutoCAD would be able to decide which Polyline to Break  at a given intersection of any two of them, and the second [maybe even more difficult], how it would be able to decide when to make a single  Break across multiple  crossing Polylines, getting only one  pair of Block insertions [instead of a pair for every one it crossed].  Your brain can figure these things out easily, but an AutoLisp routine would need a lot of help.  Can you spell out any kind of criteria for such decisions?  Are there limitations on the geometric possibilities that might occur, so that there would be fewer things to think about?
[And by the way....  With that much code, it's preferable to attach a file, rather than paste all of it into the Message body.]
Kent Cooper, AIA
Message 5 of 8
eng_mohamedmustafa
you can check this
https://www.youtube.com/watch?v=SNI-o91vbLI&t=233s
this engineer do this but the video in arabic language
Message 6 of 8
Kent1Cooper
you can check this
Have you contacted him?  There's a reference to [and spoken mention of, in English] "Update CircuitPro" at the end of the video -- is that a software package that this command is part of?  Also, if you can get it, it looks like it does only one intersection area at a time, which doesn't sound like what you originally requested.
Kent Cooper, AIA
Message 7 of 8
eng_mohamedmustafa
he makes a package contains a lot of lisps (circuit pro) ... this lisp that i requested
Message 8 of 8
eng_mohamedmustafa
if we can edit the code ... as when we choose all polylines on drawings the lisp get intersections and at breaking situation lisp decide to break polylines and keep touching polylines (overlapping) ... but I try to do this and failed !!!  have you any idea about this
