break intersection polylines and add brackets
eng.girgis.adly
Message 1 of 21
eng.girgis.adly
Good Day Guys
I ask if there is a lips to trim the intersection polylines and add splines as the attached image
Replies (20)
Message 2 of 21
devitg
@eng.girgis.adly please upload a your sample.dwg
  do a search fo
BreakObjects.lsp
or any other as
*break*.lsp
https://www.google.com.ar/search?sxsrf=ALeKk02vrVYpzq6ivz1tPZTnMmuH1dMm9w%3A1595779136817&source=hp&...
Message 3 of 21
Sea-Haven
Like Devitg when you break an object it makes a new one so when using a break.lsp remember original object then add new object using (entlast) so easy to add the squiggles as you know the end points.
Message 4 of 21
eng.girgis.adly
dear
I add a sample drawing
also I found this video for a similar lisp like what i need
https://youtu.be/qiHk41x1OQE
Message 5 of 21
eng.girgis.adly
this lisp do the required job
but without add SPlines
i need to add splines after break the line
Message 6 of 21
dlanorh
Make a block of the spline break symbol, with the correct insertion point for your requirement. Upload this block and someone should be able to alter a lisp you choose to insert this block on every new end and explode it leaving the spline.
I am not one of the robots you're looking for
Message 7 of 21
Sea-Haven
If you look at this it works out the two points for the break.
(command "._break" "_non" (trans (nth ct3 bptlist) 0 1) "_non" (trans (nth (+ ct3 1) bptlist) 0 1))
So before doing command save the pts ie pt1 pt2
Then get the angle of pt1-pt2 this is the block rotation angle.
(setq pt1 (trans (nth ct3 bptlist) 0 1)
      pt2 (trans (nth (+ ct3 1) bptlist) 0 1)
(setq ang (angle pt1 pt2))
(command "._break" "_non" pt1 "_non" pt2)
(command "-insert" "squigle" pt1 1 1 ang)
(command "-insert" "squigle" pt2 1 1 ang)
NOT TESTED !
Message 8 of 21
diagodose2009
(princ _ax)(princ"\nEnd")T)(Defun pp_esquiline(/ $rr pt1 lvert horiz $i $e)(setq $rr nil pt1(getvar"VIEWCTR"))(progn(while pt1(setq $rr(dfn_enamk_squigle nil"0"1)$rr(command"REGEN"))(setq pt1(getpoint pt1))))(setq horiz(ssget(list(cons 0"*POLYLINE,LINE"))))(setq lvert(car(entsel"\nSelect Vertical Line:")))(if lvert(ssdel lvert horiz))$rr)
You do need break of Polylines, you can clone , and you recreate the entities
Message 9 of 21
Sea-Haven
Not sure what all these are in code
(setq ;|a11829|;
Message 10 of 21
eng.girgis.adly
I tried it but it doesn't work
I attached the file after modification
Message 11 of 21
Kent1Cooper
Another possible approach:
Make a Block with a Wipeout, something like this:
The blue is the Wipeout [with WIPEOUTFRAME set to show it], and the red is the insertion base point [not part of the Block].  The "squiggles" are Polylines with a central line segment, so the Wipeout ends can coincide exactly [not possible with a Spline].
Here the Block is used [with WIPEOUTFRAME set to not show those] to "cut" crossing Lines without cutting them.  The Blocks are Inserted at the INTersections, and each one's rotation angle would follow its "cut" Line's direction [all horizontal here, but surely that's not always the case].  The visibly-but-not-really-cut Lines run through, but are hidden within the Blocks by the Wipeouts.  So if [for example] you need to know the length of crossing Lines [or Polylines, or whatever they are], they are still "whole" and that information is available.
You would need to use DRAWORDER to put the Blocks behind the continuous-through Line, and the crossing Lines behind the Blocks.  But my guess is that it would take a lot less code to implement, and would save memory, since both squiggles are covered in one  Block Insertion, and the "cut" Lines are still single objects, not split into two each.
Kent Cooper, AIA
Message 12 of 21
devitg
Hi @Sea-Haven . it seem to be a reference to who know what it is , Only @diagodose2009 could clear it
Message 13 of 21
eng.girgis.adly
I tried the attached code but it didn't work
Message 14 of 21
eng.girgis.adly
it is a nice idea my friend
Great 🙂
Message 15 of 21
Sea-Haven
Agree nice idea a single block 2 squiggles and a matching wipeout, arcs not supported in a wipeout so a little bit of close line work. Use x and y scale of block to get required look.
Message 16 of 21
eng_mohamedmustafa
Hi
this lisp i search for before and didn't find solution ... can you provide me with the lisp after final modifications
thanks
Message 17 of 21
eng_mohamedmustafa
i attach DWG contain what i mean exactly
thank you
Message 18 of 21
ВeekeeCZ
Use CAB's BreakObjects routine, possibly HERE or many other places.
Use its BreakWith command.
Then use my enclosed routine to add caps.
See HERE how it works.
Message 19 of 21
eng_mohamedmustafa
i already do this with these lisps >>> but i see in this post lisp that you can select all polylines at once ... then put required gap then the lisp do break and insert block at one shot ... this is @eng.girgis.adly  mean in this post and this is i want ... so if i have huge drawing i can with a click to do all break and insert all blocks that i mention in DWG
Message 20 of 21
ВeekeeCZ
Ohh, now I see what you mean. If that is what you want, do what he says... "For the price please contact me at the following email only... " If you have a huge drawing and this tool could save you a ton of time... not sure what you're still doing here.
