Boundary Error "Point is directly on an object"
jaimuthu
jaimuthu
(defun c:p2h (/ _addhatch _boundary b spc s)
  (defun _addhatch (spc bnd lyr / h)
    (if	(setq h (vlax-invoke spc 'addhatch achatchobject "Solid" :vlax-true))
      (progn (vlax-invoke h 'appendouterloop (list bnd))
	     (vla-put-layer h lyr)
	     (vla-evaluate h)
	     (vla-update h)
	     h
  (defun _boundary (p / e)
    (setq e (entlast))
    (bpoly p)
    (if	(not (equal e (entlast)))
      (entlast)
  (cond
    ((setq s (ssget '((0 . "POINT"))))
     (setq spc (vlax-ename->vla-object (cdr (assoc 330 (entget (ssname s 0))))))
     (setvar 'cmdecho 0)
     (command "_.undo" "_begin")
     (foreach e	(vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
       (if (setq b (_boundary (cdr (assoc 10 (entget e)))))
	 (progn (_addhatch spc (vlax-ename->vla-object b) (cdr (assoc 8 (entget e)))) (entdel b))
     (command "_.undo" "_end")
     (setvar 'cmdecho 1)
  (princ)
Moshe-A
@jaimuthu  hi,
The problem with this drawing...under each point there is a small line with 0.2 length
for test, remove this line and run the lisp and you will see it does work.
Moshe
jaimuthu
yes i did not see the line Thanks for your Reply
komondormrex
@jaimuthu
move tested point for boundary 20 units higher
	     (vla-evaluate h)
	     (vla-update h)
	     h
    (setq e (entlast))
    (bpoly p)
      (entlast)
  (cond
     (setvar 'cmdecho 0)
       (if (setq b (_boundary (mapcar '+ '(20 0) (cdr (assoc 10 (entget e))))))
     (setvar 'cmdecho 1)
  (princ)
jaimuthu
its work thanks for your reply
jaimuthu
thank
jaimuthu
work
