Blocks to polylines vertex angles
alexandra_fulger
alexandra_fulger
Hi all,
In a drawing l have many polylines, and I need to insert specific blocks at different angles of the polyline segments. So let's say that I have a polyline that has some segment angles between 40-47 degrees. I need to insert in those vertex a block named "c45". Is there a way to do that with a lisp?
Do you think it could be possible? do you have any tips for me?
Thanks a lot in advance!
komondormrex
hey,
where exactly a certain block should be inserted with regard to a segment?
alexandra_fulger
Hey! The blocks should be inserted as shown in my dwg. Can it be done to select more than just one polyline at a time?
komondormrex
hi,
sure it can. check the following code.  block 'c45' should be defined in the drawing.
(defun c:mark_segment_angle ( / param repeat_count vector_1 vector_2 cos_alpha sin_alpha alpha)
	(if (setq pline_sset (ssget '((0 . "lwpolyline"))))
		(foreach pline (vl-remove-if 'listp (mapcar 'cadr (ssnamex pline_sset)))
			(setq param 0
				  repeat_count (fix (vlax-curve-getendparam pline))
			(repeat (1- repeat_count)
					(setq vector_1 (vlax-curve-getfirstderiv pline param)
						  vector_2 (vlax-curve-getfirstderiv pline (setq param (1+ param)))
						  cos_alpha (/ (apply '+ (mapcar '* vector_1 vector_2))
									   (* (sqrt (apply '+ (mapcar 'expt vector_1 '(2 2))))
									   	  (sqrt (apply '+ (mapcar 'expt vector_2 '(2 2))))
					(cond
							(equal 0 cos_alpha 1e-8)
								(setq alpha (* 0.5 pi))
							(equal 1.0 cos_alpha 1e-8)
								(setq alpha 0)
							t
								(setq sin_alpha (sqrt (- 1 (expt cos_alpha 2)))
						  		      alpha (atan (/ sin_alpha cos_alpha))
					(cond
							(< (/ (* 40 pi) 180) alpha (/ (* 47 pi) 180))
								(vla-insertblock (vla-get-block (vla-get-activelayout (vla-get-activedocument (vlax-get-acad-object))))
																(vlax-3d-point (vlax-curve-getpointatparam pline param))
																"c45"
																0.0254 0.0254 0.0254 0
							t
;					(print (angtos alpha 1 6))
	(princ)
alexandra_fulger
alexandra_fulger
Thank you so much! You really helped me a lot! Wow!!!
komondormrex
your welcome)
