Blocks and Nested Blocks list to ssname.
regisrohde
regisrohde
Hi
I need a list of ssname of all design blocks including nested. To check the list after separate XDATA condidos in blocks. Thanks.
(while ent (setq elst (entget ent))
(if (= (cdr (assoc 0 elst)) "INSERT")
(progn
(princ ent)
(verifyxdata); routine that checks for xdata
(princ "******************")
(setq ent (entnext ent))
Please mark this as the solution if it resolves your issue.Kudos gladly accepted.
Regis Rohde
regisrohde
Modify a lisp code by _gile :
http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-can-i-count-blocks-within-blocks/...
(defun nested-count (bname / blk ent elst cnt)
(setq blk (tblsearch "BLOCK" bname))
(setq cnt 0)
(setq ent (cdr (assoc -2 blk)))
(while ent
(progn
(MONTLIST)
(setq cnt (+ cnt 1 (nested-count (cdr (assoc 2 elst)))))
cnt
(defun c:blk-count (/ ss cnt n ent)
(setq cnt 0 n -1)
(if (setq ss (ssget "_X" '((0 . "INSERT"))))
(progn
(setq cnt (sslength ss))
(while (setq ent (ssname ss (setq n (1+ n))))
(MONTLIST)
(setq cnt (+ cnt (nested-count (cdr (assoc 2 (entget ent))))))
(DEFUN MONTLIST ()
(SETQ MLISTS (cons ENT MLISTS))
tanks
Regis Rohde
