BLOCKREPLACE command problems
So I'm working in Civil 3D 2021 and we often have to clean up surveys from several different companies. Some of them use add-on civil3D software and others use something completely different. We have to change out the symbol blocks on all of these with our own. The problem I'm running into is the BLOCKREPLACE command only changes out the block definition which leaves all kinds of corruption embedded into the blocks. A couple examples of these remnants are attributed block text, and other coding those add-ons attach to the block definition. Redefining the blocks doesn't remove these remnants.
What I'm looking for is a routine that is block version of the LAYTRANS command. I can't tell you how many times I've wasted hours having to place new blocks inside old blocks and burst/explode them. I would like it to be block name based like LAYTRANS, put the new blocks in the same spot as the old ones, and matching the previous blocks layers/linetypes/size(x,y,z)/rotation would be helpful. Big thanks to anyone who can help!
Civil 3D x64 2019
Win 10 x64 Pro
Intel Xeon E5-1620
32 GB Ram
