Block Solid Hatch Color to Byblock
jyan2000
jyan2000
Hello Forum ,
I found this lisp changes colors all SOLID pattern hatches inside blocks to white ,
how can i change color to byblock or bylayer or selected color ( red, magenta etc. )
(defun c:sol2white (/ doc)
(or *colorobject*
(setq *colorobject*
(vla-getinterfaceobject
(vlax-get-acad-object)
(strcat "AutoCAD.AcCmColor." (substr (getvar "acadver") 1 2))
(if
(null (vl-catch-all-error-p (vl-catch-all-apply 'vla-setrgb (list *colorobject* 255 255 255))))
(progn (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))
(if (= :vlax-false (vla-get-isxref blk))
(vlax-for obj blk
(if (and (= "AcDbHatch" (vla-get-objectname obj))
(= "SOLID" (strcase (vla-get-patternname obj)))
(vlax-write-enabled-p obj)
(vl-catch-all-apply 'vla-put-truecolor (list obj *colorobject*))
(vla-regen doc acallviewports)
(princ)
(vl-load-com)
(princ)
Best regards
Victor
komondormrex
hi there,
check this
(defun b_hatch_color (color)	;	0 - byblock, 1-255 - index colors, 256 - bylayer
	(vlax-map-collection (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
						'(lambda (block) (if (and (zerop (vlax-get block 'islayout))
												  (zerop (vlax-get block 'isxref))
												(vlax-map-collection block
													'(lambda (object) (if (and (= "AcDbHatch" (vla-get-objectname object))
																			   (= "SOLID" (vla-get-patternname object))
																		  (vl-catch-all-apply 'vla-put-color (list object color))
	(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
	(princ)
jyan2000
Thank you very much for quick respond.. I could not able to run this lips .. Which part am I doing wrong ?
Regars,
Victor
komondormrex
do as follows
1. load the code in autocad.
2. call the function loaded in command line with color needed, eg. (b_hatch_color 1) - to set solid hatch color in blocks to red.
paullimapa
give this modified version called ChHatSolCol a try:
; ChHatSolCol changes Solid Hatch colors based on ACI selection
; Modified from c:sol2white
; OP:
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/block-solid-hatch-color-to-byblock/m-p/12732266#M465013
(defun c:ChHatSolCol (/ doc)
(vl-load-com)
(or *colorobject*
(setq *colorobject*
; add 255 AutoCAD Index color selection
(setq *color* (acad_colordlg 7))
(if
(vlax-for obj blk
;(vl-catch-all-apply 'vla-put-truecolor (list obj *colorobject*))
; change color based on selection
(vl-catch-all-apply 'vla-put-color (list obj *color*))
(princ)
(princ)
Paul Li
IT Specialist
@The Office
jyan2000
Thank you Very much.. Its works Perfect..
Best Regards
Victor
paullimapa
Glad to have helped… cheers!!!
Paul Li
IT Specialist
@The Office
