Hi.
Im kind of stuck how to build my code since im a beginner. And i was looking for someone that could help me? 😃 😛
Im looking for a routine that will scale my blocks. and keep them att the point that they are inserted in.
I want to be able to scale multiple blocks by selecting them.
save the point for example this, and not move them.
(10 -55100.0 -28500.0 0.0)
I want to filter so i cant choose anything else.
(0 . "INSERT")
Modify dxf codes
(41 . 50.0) (42 . 50.0) (43 . 50.0)
Its also omportant that all my content in my block also scales, i found a routine that will scale but my attribute inside is still att scale 1 instead of my new value 50.
how can i include a getkword function with my (50 100 150 200 250 300 350 400) scale options?
I used this one from Lee Mac but it wont fulfil my needs to 100%.
(defun c:scl ( / enx idx scl sel ) (initget 6) (if (and (setq scl (getdist "\nSpecify scale factor: ")) (setq sel (ssget "_:L" '((0 . "INSERT")))) ) (repeat (setq idx (sslength sel)) (setq enx (entget (ssname sel (setq idx (1- idx))))) (foreach dxf '(41 42 43) (setq enx (subst (cons dxf scl) (assoc dxf enx) enx)) ) (entmod enx) ) ) (princ) )
