block rename lsp
block rename lsp
nychoe1
block rename lsp
nychoe1
hello,  I have a lsp that changing block name
this lsp changed  Anonymous name but do not change block name. why?
attached image file
I want to change block name. not Anonymous name
(defun c:bb (/)
   (setq ss (entsel "\nselect"))
   (setq ent (car ss))
   (setq ent_list (entget ent))
   (setq blk_name (cdr (assoc 2 ent_list)))
   (setq acad_obj  (vlax-get-acad-object)
         doc (vla-get-ActiveDocument acad_obj)
         blocks    (vla-get-blocks doc)
         blk_old   (vla-item blocks blk_name)
   (setq new_name (getstring (strcat "\ncurrent <" blk_name "> new name ")))
   (vla-put-name blk_old new_name)
   (princ)
);defun
dbhunia
Try this...
attached image file
(defun c:bb (/)
   (setq ent (car ss))
         blocks    (vla-get-Blocks doc)
   (princ)
);defun
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
cadffm
@dbhunia
Function names are not case-sensitive
@nychoe1
Why should?
Why should  the real blockname change (called "anonymous Name" in LIST command output, but it is the real name and the other one is the fake name = EFFECTIVENAME).
You selected and changed the Block "BlockA", no other blocks, just this one, you didn't rename Block "*U24", or?
Rule1: A Block is just one time in the document, all block-references of this block displays this one block content,
so all blockreferences looks the same (except few thing ~ rotation, scaling, byblock , Layer0..)
Rule1 was correct 20 years ago, Rule1 is correct still today, so how are dynamic blocks possible? Aren't possible, it's just a fake.
Crash course dynamic Block concept overview:
Block-defintion BlkA (dynamik block, say a stretchable rectangle).
Create a new block-reference, it is 100% the same like a non-dynamic block, block-reference refer to block BlkA.
Now, you change the dynamic parameter (stretch the rectangle)...
In the background autocad creates a new block with ab block name "*Unnn",
the edited block-reference refer to block "Unnn" now, and not longer to Block BlkA.
But AutoCAD knowing that "*Unnn" is a variant of "BlkA" (on good days)
and you can get the "template blockname" by EFFECTIVENAME property.
Change you Lisp from
to
   (setq blk_name (vla-get-effectivename (vlax-ename->vla-object ent)))
Sebastian
nychoe1
thank you...
