Block name and Description to Multileader
Francisco_Melo
Francisco_Melo
I already have a lisp that converts the name of a block to a multileader.
I was wondering if it is possible for him to give the name and in another line the description of the block.
Thank you.
(defun c:BNameLabel (/ ent entl obj)
(cond ((not (setq ent (car (entsel "\nSelect block: ")))))
((not (eq (cdr (assoc 0 (entget ent))) "INSERT")) (princ "\nInvalid object!"))
((setq pt (getpoint "\nSpecify first point: "))
(setq entl (entlast))
(vl-cmdf "_.mleader" "_non" pt "\\")
(while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf ""))
(if (not (equal entl (setq entl (entlast))))
(vla-put-textstring
(vlax-ename->vla-object entl)
(vlax-get-property
(setq obj (vlax-ename->vla-object ent))
(if (vlax-property-available-p obj 'EffectiveName)
'EffectiveName
'Name
(princ)
(vl-load-com)
(princ)
pbejse
(defun c:BNameLabel (/ efnmae ent entl obj)
	   (vla-put-textstring
	     (strcat  (setq efnmae
		     (vlax-get-property
			 'EffectiveName
			 'Name)
		      "\\P"
		     (cdr (assoc 4 (tblsearch "block" efnmae)))
  (princ)
(vl-load-com)
(princ)
HTH
Francisco_Melo
Good Morning.
Thank you very much Pbejse for your great contribution. But if by chance the block has nothing in the description it gives an error and does not advance says (Block does not have a description «!»). It could go ahead and put the data that had available.
Thank you.
pbejse
@Francisco_Melo wrote:
..But if by chance the block has nothing in the description it gives an error and does not advance says (Block does not have a description «!»).
Is it on one particular drawing or in any drawing?  This snippet will yield a blank string if the description is not availabe. unless the block with the specified named is not found of course.
Can you explain that more in detail @Francisco_Melo .
Yup, that is the general idea.
perhaps this
(if (setq desc (cdr (assoc 4 (tblsearch "block" efnmae)))) desc "")
in place of the above
