block multiplication in a contour
r_florinus
r_florinus
Hi, I need you to help me too. I have an irregular outline and I want to fill it with a block. the block is rectangular, I hope to find something to create the block to select the contour and the block. inside the contour to multiply the blocks. but where a block does not enter, do not place it. does anyone know an order like this? thanks
 I also attached pictures with an example of contour, block and how I want it to look at the end
3wood
You can try SMARTSEL.
1. Array the whole area with the block.
2. Use Smartsel -> WP -> No to select all whole blocks inside the polyline. Then press Esc.
3. Use ERASE select all objects, then use "R" option then "P" to remove previous selected objects from the selection set.
Satish_Rajdev
I’ve already developed the kind of tool which you are looking for, You can see a tool demo in the following link:
https://www.youtube.com/watch?v=vWXKo2AogRo
For solar design automation, I’ve also created other tools also for the electrical & civil side for both ground mount & rooftop projects. I’ve specialization in-ground mount projects mainly. These tools are not freeware so I can’t share them directly, to take this discussion forward you can reach me at satish@rey-techs.com
Best Regards,
Satish Rajdev
REY Technologies | Linked IN | YouTube Channel
