Block attribute tag to multileader
ssuoiresos
Message 1 of 9
ssuoiresos
Hi all. I have attached a lisp program BNAMELABEL.LSP which at the moment reads the name of a block and place it in a multileader. I would like someone to change this program to do the following.
-to read one of the block attributes, named "ATT", instead of the name of the block, and attach it to the multileader
-the font size of the text for the multileader to be set as  200 instead of 4 that is now
- somehow the "REGEN" command to be used, so that if some of the attributes named "ATT" in the blocks will be changed, using the REGEN command, the block multileaders to update accordingly.
I tried to modify this lisp routine myself but I got so many errors...
Many thanks.
Replies (8)
Message 2 of 9
Sea-Haven
You can select a attribute directly no need to get block 1st.
(defun c:BattLabel (/ ent )
(while (setq ent (car (nentsel "\nSelect block attribute: Enter to exit :")))
(if (eq (cdr (assoc 0 (entget ent))) "ATTRIB")
	(progn
		(setq pt (getpoint "\nSpecify first point: "))
		(vl-cmdf "_.mleader" "_non" pt "\\" (cdr (assoc 1 (entget ent))))
		(alert "You did not pick a ttribute ")
 (princ)
Message 3 of 9
pbejse
@ssuoiresos wrote:
Hi all. I have attached a lisp program BNAMELABEL.LSP...
... -to read one of the block attributes, named "ATT", instead of the name of the block,..
...  using the REGEN command, the block multileaders to update accordingly.
Credit to the author
(defun c:BNameLabel (/ ent entl obj)
;;	CADTutor Alanjit Jun 2013	;;
I addition to @Sea-Haven contribution
(defun c:BattLabel (/ ent mySourceID  str pt)
(if (and (eq (cdr (assoc 0 (entget ent))) "ATTRIB")
	 (eq (cdr (assoc 2 (entget ent))) "ATT"))
	(progn
	  (setq mySourceID (itoa (vla-get-objectid (vlax-ename->vla-object ent))))
	  	(setq str (strcat "%<\\AcObjProp Object(%<\\_ObjId "  mySourceID
		                        		">%).TextString>%"))
		(vl-cmdf "_.mleader" "_non" pt "\\" str)
 (princ)
 HTH
Message 4 of 9
ssuoiresos
Hi. Thank you for your quick reply. Not sure what do you mean by "You can select a attribute directly no need to get block 1st". This attribute that will be copied in the multileader, is different for every block. So I am not sure how can I do that without selecting the block that I want to label. Anyway, when I run this lisp it just gives me the message "You did not pick a attribute"...
Message 5 of 9
pbejse
(defun c:BNameLabel (/ ent entl obj str mySourceID)
;;	CADTutor Alanjit Jun 2013 | pbe 2021	;;
 (cond ((not (setq ent (car (entsel "\nSelect block: ")))))
       ((not (eq (cdr (assoc 0 (entget ent))) "INSERT")) (princ "\nInvalid object!"))
       ((not (assoc 66 (entget ent))) (princ "\nNo Attributes on this block!"))
       ((setq pt (getpoint "\nSpecify first point: "))
        (setq entl (entlast))
        (vl-cmdf "_.mleader" "_non" pt "\\")
        (while (eq (logand 1 (getvar 'CMDACTIVE)) 1) (vl-cmdf ""))
        (if (and
	      (not (equal entl (setq entl (entlast))))
	      (setq mySourceID (Vl-some '(lambda (at)
			(if (eq (vla-get-tagstring at) "ATT")
			  	(itoa (vla-get-objectid at))))
				      (Vlax-invoke (vlax-ename->vla-object ent) 'GetAttributes)))
	  (progn
          	(vla-put-textstring (vlax-ename->vla-object entl) str )
		  (vl-cmdf "_updatefield" entl "")
		  (vlax-put  (vlax-ename->vla-object entl) 'TextLineSpacingStyle 2)
	  (princ "\nAttribute \"ATT\" not found")
 (princ)
(vl-load-com)
(princ)
HTH
Message 6 of 9
ssuoiresos
Brilliant. This is what I need. I am sorry to be a pain but what do I need to change in your code for the text to appear without grey mask (I know it won't print like that...). I think now appears like a sort of field. Thank you.
Message 7 of 9
pbejse
Its because it is a field. so when the user change the value of the attribute, the value onthe mleader wil hcange as well.
You can turn the "grey mask" off with.
Command: FIELDDISPLAY
Enter new value for FIELDDISPLAY <1>: 0
Otherwise here's a non-field code
(defun c:BNameLabel (/ ent entl obj str)
        (if (and
	      (setq str (Vl-some '(lambda (at)
			  	(vla-get-textstring at)))
 (princ)
(vl-load-com)
(princ)
Message 8 of 9
ssuoiresos
Sorry. I should have done my homework regarding the FIELDDISPLAY command. Didn't really used fields before. I will leave the 200 standard text height for another day. 😁 Thank you so much for changing the code for me. Have a great day.👍👍👍
Message 9 of 9
brk77284027
Hi can you make one lisp, to callout the attribute values in to Multileader text as shown below image
