Block Attribute Table Modification
Hello I am new to LISP and found this code online which has worked really well. I made a few modifications to start but I am having trouble with the last modification I would like to make. Currently the chart supplies a count of the components. I would like instead of a count for the "QTY" attribute to be summed for any object with the same name. Thank you in advance for your help!
DannyNL
Doesn't the standard Extract Data (Ribbon Insert --> Linking & Extraction --> Extract Data) give you the output you need?
Ranjit_Singh
Very lightly tested based on what I understood (and I might have not understood it right)bomt.gif
f_witteveen
can anyone change the list so it does not give the following in the table: coutn, name, qty.
i just need a lisp that gives the attibute values .
