Kenny,
Do you have a specific "how to" question?
Basically the trick for Bigfonts is understanding how the Escape Character
Byte Offset affects your shape definitions... At least it was for me.
Perhaps this example will get you on your way...
; Escape Char = ` : 24576 : 60 00
; Subshape Codes
; / - 00 2F
; 0 - 00 30
; 1 - 00 31
; 2 - 00 32
; 3 - 00 33
; 4 - 00 34
; 5 - 00 35
; 6 - 00 36
; 7 - 00 37
; 8 - 00 38
; 9 - 00 39
*BIGFONT 50,1,060,060
*0,5,DJK-Bigfont Characters
21,7,2,21,0
*24608,5,backspace
2,8,(-21,0),0
*24609,33,eleven sixteenths
2,0A4,4,03,3,04,7,031,7,031,4,04,3,03,0AA,7,02F,06A,048,4,03,3,04,
7,031,7,036,4,04,3,03,064,0
*24610,29,two thirds
2,0A4,4,03,3,04,7,032,4,04,3,03,0AA,7,02F,06A,048,4,03,3,04,
7,033,4,04,3,03,064,0
*24611,33,thirteen sixteenths
2,0A4,4,03,3,04,7,031,7,033,4,04,3,03,0AA,7,02F,06A,048,4,03,3,04,
Compare the above with the help file info and see if you can make sense of
it...
Notice that the line:
determines what the escape character will be - in this case: ` (HEX 60 00)
Which will mean, in this example, a Escape Character Byte Offset of 6*16*256
= 24576
You may wish to use a different escape character, or even more than one,
depending on the number of bigfont characters you need to create. If so,
you'll need to calculate the escape character byte offsets for each one, and
create your shape definitions accordingly. But keep in mind that the more
escape characters you make use of, (or if they are poorly chosen) the
greater the risk of unexpected text display results. (Think of the chaos
that would most likely ensue if you were to foolishly choose some common
character, like the letter 'A', as an escape code!) WH?! THIS IS CR?Y!
The lines beginning with *24### following the main header are the individual
shape definitions.
What determines the number is that same Escape Character Byte Offset (here
24576, remember?) + the ASCII value of the keyboard character you wish to
use... so then:
*24608 = 24576 + 32 (ASCII 32 = )
*24609 = 24576 + 33 (! [Shift 1])
*24610 = 24576 + 34 (")
*24611 = 24576 + 35 (# [Shift 3])
Result:
` 'draws' a backspace
`! draws an 11/16 fraction [Shift 1, remember?]
`" draws a 2/3 fraction
`# draws a 13/16 fraction [Shift 3, remember?]
etc.
You should be able to understand the rest of the gobbledy-gook above via the
help files, but if not, feel free to post a specific question.
At any rate, if you can infer from the above (in MY bigfont shape code
definitions NOT posted) that typing a `7 keyboard sequence would draw a 7/16
fraction and a `@ keyboard sequence would draw a 3/4 fraction, I must say
that you are well on your way to understanding whatever the hell it was I
just posted. ;)
hth,
David Kozina
PS - Excellent reference (out of print and perhaps very hard to find):
"Maximizing AutoCAD R13" by Gesner, Middlebrook, and Tanzillo.
PPS - Using subshapes when possible is very nice way to optimize and reduce
your shape definition coding, as I hope the above also demonstrates.
"kboykool" wrote in message
news:25527968.1095698497500.JavaMail.jive@jiveforum1.autodesk.com...
> When I was looking to learn AutoLISP, a CAD instructor recommended that I
get a copy of AutoLISP in Plain English (George O. Head). This was a great
reference and I was able to create a couple routines.
> Now I'm looking to build an extended font. I have read here that the
online help is the best reference for creating an SHP file for Bigfont use.
However, I have looked through this and found it to be lacking. Is there
any other reference that could help me learn to create what I'm seeking?
> Thanks.
> Kenny Anderson
> xengineerx@xkboykoolx.com
> (Remove e'x'es to reply)
