Beam longitudinal section
prash1730
prash1730
  • Namaste,
    Can anyone please help me out with a lisp to draw LS of beam for upto 8 spans giving the following options (can take input from xlsm)
  • Draw outline using chosen points from plan layout.
  • Top layer bars in each span
  • Additional top layer bars in each span
  • Bottom layer bars in each span
  • Additional bottom layer bars in each span
  • Option to change depth of any span
  • Curtailments at top and bottom.
  • Dimension of each span
  • Suport width of each span.
It would be of tremondus help!!
Thank you for your valuable time and support Best regards,
PNP
Sea-Haven
What no sample dwg ?
This request is the sort of thing that you should pay for, after all some one will have to spend a lot of time making a dcl front end to suit, asking questions about double reo, and so on. Then draw it all and do the dimensioning and so on, let alone the 4 goes to get all the options worked out.
This is not your beam but a custom program, look at GIF to get an idea of what you could do.
prash1730
Namaste,
Thanks a lot for your quick reply @Sea-Haven. PFA typical LS and layout. It can be done using Lisp only i believe. I found few lisps on the net but it was not suiting my requirement. Hence, tried to do it using AI (as i had worked in VBA long back and don't remember much 🙂 ). However, that also seem to be not working properly.
Best regards,
prash1730
Sea-Haven
The dwg is extremely complicated and sorry for me would have to be a paid solution, doing all the bent bar combos would take a lot of thought, hook ends, so many different bar shapes required, single bent bar 1 end or 2, that is just from a minute or 2 looking at your dwg. probably like 10 separate functions required. Then we get onto dims & leaders. Can add say xdata to beams that contains dia and lengths for quantities another big task.
I can see why you want something.
Reading the leader for bar dia is easy, checking for p/line close to can be done and then get length, useful in case leader does not touch a object.
Ps if you used CHATGP to try to write lisp, give up, it will write code with so many problems people like me throw it away and start again.
prash1730
Thank you for your response @Sea-Haven 🙏🙏
