Visual LISP, AutoLISP and General Customization
Basic lisp to bind xref's explode the blocks then layer isolate layer
10 REPLIES 10
Message 1 of 11
bgraverholt
2044 Views, 10 Replies
I am trying to work on  a lisp where It binds (insert) all xrefs in a drawing, the selects all blocks and explode, then layer isoloate floor plan layer, select all floor plan objects scale down .001.
The code below is basic and gets stuck on the explode section.
(defun c:keyplan ()
  (setvar "BINDTYPE" 1)
  (command "_-xref" "_bind" "*")
  (command ".explode" "all" "")
  (command "layiso" "*floor*plan*" "" "scale" "all" "" ".001")
  (princ)
Tags (3)
10 REPLIES 10
Message 2 of 11
Moshe-A
in reply to: bgraverholt
Unfortunately, an explode command coming from (command) function accepts only one argument
to overcome this there is an undocumented system variable called QAFLAGS
if it set to 1, the explode will work as expected
cheers
Moshe
Message 3 of 11
ВeekeeCZ
Use (initcommandversion) to allow multiple selection in lisp version of the explode command.
The layer isolation command does not work that way. Use the  -LAYER command instead. Turn off all layers first, then use your wildcard pattern to turn on layers you want.
Where is the base point for the SCALE command. Is it '(0 0 0) ?
Message 4 of 11
bgraverholt
in reply to: Moshe-A
I added the following that I found on line but it still gets hung up on the explode command. I have tried all instead of * and still nothing. I know I still have something wrong lol
(defun c:keyplan ()
  (setvar "qaflags" 1)
  (command ".explode" (ssget) "" "*")
  (setvar "qaflags" 0)
  (princ)
Message 5 of 11
Moshe-A
this is wrong
this is good
(command ".explode" (ssget) "")
Message 6 of 11
bgraverholt
When running that it will also hang up and ask me to select blocks. This is what the command line states when I run it.
Duplicate Block "HC-SYMB" ignored.
Command: .explode
Select objects:
Message 7 of 11
Moshe-A
Seperate your lisp to tasks:
1) prepare a drawing with binded xrefs
2) activate the explode on them, fix your code until it works
3) the (command "layiso")  is wrong and redundant
it is not good coding to invoke (ssget) as an argument to (command) function...cause if the selection yield noting, your program will be fail on the explode command and probably continue to fail on scale
you do not need to isolate layers in order to select objects on specific layers, instead (ssget) function has a filter argument which can select all
objects on specific layers.
check this:
(if (setq ss (ssget))
 (progn
  (command ".explode" "si" ss)   ; the "SI" argument means "single" options for select objects
                                 ; which spare the need for enter to finish the selction objects
  (if (setq ss (ssget "x" '((8 . "*floor*plan*")))) ; select all objects on "*floor*plan*" layers
    						    ; the "x" argument disable pausing for auto select
   (command ".scale" "si" ss "0,0" "0.001")         ; then scale by 0.001
 ); progn
); if
why scale by 0.001? if the objects are small you wont see the any change.
Moshe
Message 8 of 11
bgraverholt
That does work but it still requires input from user to explode the xref blocks. Is there away to select all and explode? For the scaling down everything on floor plan it doesn't include blocks that are on layer 0 but the objects inside the block are on floor plan layer. Is there a way to include them also? It would be best if it would layer isolated floor plan first before scaling for the fact that the drawing has multiple other layers in the drawings so when it scales down you have to go find the scaled down floor plan at 0,0 rather than doing a general selection to find the floor plan.
Message 9 of 11
DannyNL
This will explode all blocks in your drawing.
Replace your (command "explode"...) with (ExplodeAllBlocks)
(defun ExplodeAllBlocks (/ EAB_BlockSelection)
   (if
      (setq EAB_BlockSelection (ssget "_X" '((0 . "INSERT"))))
      (progn
         (foreach EAB_Entity (ssnamex EAB_BlockSelection)
            (vl-catch-all-apply 'vla-Explode (list (vlax-ename->vla-object (cadr EAB_Entity))))
(defun c:keyplan ()
  (ExplodeAllBlocks)
Message 10 of 11
bgraverholt
in reply to: DannyNL
For what ever reason I am having a hard time following what I need to all show in this lisp. I know I need to isolate floor plan and still scale everything down by .001 but do I just add that after the code you wrote?
Message 11 of 11
Kent1Cooper
@bgraverholt wrote:
That does work but it still requires input from user to explode the xref blocks. Is there away to select all and explode? .....
Don't use (ssget) -- that's what's asking the User for input.
(command ".explode" "_all" "")
Kent Cooper, AIA
Forma Design Contest
