Message 1 of 9
I do a lot of baseline dimensions around cylinders for markups.
Autocad gives baseline extension lines that are square to the cylinder above 90° which is neat and tidy especially when you have several points to dimension that are close together to mark up. Below that 90 degrees the format changes to an oblique extension line that is very untidy and makes it impossible to dimension items close together.
Attached an image below.
Is there a way to get dimensions below 90 degrees to display like above 90 degrees?
