Automation of Block Assignment
frjuniornogueira
Message 1 of 8
frjuniornogueira
Hello everyone,
First of all, thank you for your feedback. I have a situation I’d like to automate, but I’m not sure if it's possible.
I have some polylines with blocks at their vertices, and these blocks come in three types:
  • At the beginning of a polyline, if there is only one, the block is type 1. (photo)
  • If there are two at the beginning, the block will be type 3. (photo)
  • If the polyline makes a sharp angle, the block will also be type 1.
  • If the angle is right or has a slight angle, the block will be type 2.
I'm attaching a DWG file as an example of how it should look. Is it possible to create a command to automate this process? The block is already placed at the polyline vertices; it just needs to be assigned the correct type in the attribute.
Replies (7)
Message 2 of 8
Sea-Haven
Two comments "already placed at the polyline vertices" the 2 TYPE-2 on left are at 1/3 point not vertice.
The Type-1 red pline does not appear to have any angle change so should be TYPE-2.
It may need to walk through the plines two times, as need to check for a gap but not be an end point.
Like others will have a think about it.
It may be easier to insert the blocks rather than try to amend them. Insert to vertices do 1st and so on. Then can do add blocks at 1/3 rd points.
Message 3 of 8
frjuniornogueira
It's not possible, the blocks will always be in the project, that was the reason I thought it wouldn't be possible to do the automation.
I couldn't understand your other questions.
Message 4 of 8
Sea-Haven
This should explain my questions.
What I was suggesting was to do the check when inserting the block so it gets correct Attribute at that stage, that would be my way to do it, maybe a couple of options but in one code.
The 2 blocks at say a 1/3rd spacing would be obvious that they are Type-2. So a separate function asking for ratio 2, 3, 4 and so on within a pline or line segment.
Vertex second function.
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/automation-of-block-assignment/td-p/13012643
(defun c:ins2 ( / oldsnap num start end pt lst )
(setq oldsnap (getvar 'osmode))
(setvar 'osmode 0)
(setvar 'attreq 1)
; (setq obj (vlax-ename->vla-object (car (entsel "\nPick line or pline object "))))
(setq obj (vlax-ename->vla-object (car (entsel "\nPick line  "))))
; (setq objtyp (vlax-get obj 'objectname))
; next version check for pline segment
(setq num (getint "\Enter the number of segments "))
(setq start (vlax-curve-getstartPoint obj))
(setq end (vlax-curve-getEndPoint obj))
(setq ang (angle start end))
(setq spac (/ (distance start end) num))
(setq lst '() dist 0)
(repeat (- num 1)
(setq pt (polar start ang (setq dist (+ dist spac))))
(setq lst (cons pt lst))
(foreach pt lst
(setq pt (mapcar '+ pt (list 0.0 -2.95 0.0)))
(command "-Insert" "block_teste" pt 1 1 0 "TYPE-2")
(setvar 'osmode oldsnap)
(princ)
(defun c:ins1 ( / )
(alert "to be done")
; vertice points with or without gap.
Again starting with no block and inserting starting to get somewhere. Need to adjust insertion point.
The remaining vertices will be easier to do.
Message 5 of 8
frjuniornogueira
Can insert it at any vertex, this won't be an issue. It just needs to check if there are two polylines.
Message 6 of 8
frjuniornogueira
 The example I showed you is correct. Type 02 should be placed where there are no sharp curves and can never be used more than twice in a row. Whenever you insert two, the next one must be Type 01.
That was exactly what made me think it wouldn't be possible.
Message 7 of 8
Sea-Haven
"Whenever you insert two, the next one must be Type 01." When getting pline vertices can keep count and do its "3rd" insert, so put Type-1 not Type-2.
Still working on it. Its happy hour time.
Message 8 of 8
frjuniornogueira
I understand, but this is the standard, it should be this way.
