Automatically cutting sections with Lisp routine?
Hi there,
I am looking for a solution to increase productivity through AutoCAD.
When cutting sections through 3D geometry consisting of only 3D Polylines.
WHen I do this manually, i use a line at z=0 than use the APPARENT INTERSECTION object snap to trace along this line and the intersections of the 3D geometry which creates a straight line through this section that can be then flipped up (i have worked this part out with an action macro) to create a 2D section of the slice. (please see image below to see what I am talking about)
Would it be possible to automate this routine by using Lisp?
If so I would be very appreciative if you could show me how as this would be a very big timesaver when cutting a vast number of these sections again in the future.
SAMPLE DWG ATTACHED
*I am aware that Civil 3D can do this but I primarily work with Autocad and the SECTIONPLANE command doesnt appear to work with polylines, only preexisting 3D elements*
Many thanks!
