Automatic_area_LISP_customization
Lukasvop1
Message 1 of 33
Lukasvop1
Hi guys,
I found great lisp for automatic calculating area inside closed polyline created by Ronald Maneja  but I need customized it for myself. It's probably easy but I'm not programmer so if you have a little bit of time can you watch this? Thank you.
I need this 3 things :    1. Change ''.'' to '',''  -  e.g  25.3 to 25,3
                                        2. Number format   -  e.g. 25 to 25,0  (after whole numbers add ,0)
                                        3. Allow add Suffix -  e.g  25,3 to 25,30 m²
;;; CADALYST 07/08 www.cadalyst.com/code
;;; Tip 2292: AreaRon.lsp Area of Closed Polylines (c) 2008 Ronald Maneja
;;; PRODUCES TEXT CONTAINING AREA OF SELECTED CLOSED POLYLINES
;;; AND PUTS THEM IN AREARON LAYER
;;; CREATED BY RON MANEJA 31JAN08
;;; USER INPUTS: SCALE, POLYLINE SELECTION
(defun C:AREARON (/
allx
ally
areaobj
counter
ctr
el
entity-name
entnamevla
mysset
pt
tst
vertex
x
y
(vl-load-com)
(COMMAND "_.UNDO" "BE")
(set_var)
(if (tblsearch "Layer" "AREARON")
(command "._layer"
"_thaw"
"AREARON"
"_on"
"AREARON"
"_unlock"
"AREARON"
"_set"
"AREARON"
) ;_ closes command
(command "._layer"
"_make"
"AREARON"
"_color"
1
"AREARON"
) ;_ closes command
(if (null sch)
(setq sch 1.0)
(initget 6)
(setq temp (getreal (strcat "\nENTER SCALE <"
(rtos sch 2 2)
Replies (32)
Message 2 of 33
paullimapa
no modifications required, check out my free open-source code Area Object Link app
Paul Li
IT Specialist
@The Office
Message 3 of 33
Lukasvop1
Message 4 of 33
Lukasvop1
I saw your app and work's well but if you have large floor plan with 100+ rooms just suck. This is totally different league just customized it..
Message 5 of 33
paullimapa
Unfortunately the AREAON.lsp you're referring to has the following limitations:
1. Uses vla-get-area function which does not allow for formatting
2. Do not use FIELDS so when the pline changes in shape/size, the area values will not update
Paul Li
IT Specialist
@The Office
Message 6 of 33
Lukasvop1
Well, maybe have some limitation for some cases but If don't need update individual areas (I think it's really rare ) it's 100x faster than your AOL app (nothing personal).
Message 7 of 33
paullimapa
I understand what you are trying to do but the code will requires a complete rewrite so not as simple as just modifying it
Paul Li
IT Specialist
@The Office
Message 8 of 33
Lukasvop1
I thought it's just a few easy changes, as I write I'm not a programmer so hope it will see some passionate programmer and be able to rewrite it, I really appreciated it and think many other people here too.
Message 9 of 33
_Tharwat
Could you post the entire codes so me or anyone else could suggest a solution for your desired mods ?
Message 10 of 33
paullimapa
See link in message 5
Paul Li
IT Specialist
@The Office
Message 11 of 33
_Tharwat
Replace this
(command "text" "j" "mc" pt (* sch 2.5) "0"(rtos areaobj 2 precision))
With this
(command "text" "j" "mc" pt (* sch 2.5) "0" (strcat
(vl-string-translate "." "," (rtos areaobj 2 precision)) " m²")
Message 12 of 33
paullimapa
excellent trick...I was just thinking of doing this as a bandaid....
Paul Li
IT Specialist
@The Office
Message 13 of 33
paullimapa
Inspired by @_Tharwat change the same line of code so that it'll be a FIELD that will automatically update the AREA when the PLINE shape changes:
Existing code:
Modified code:
(strcat "%<\\AcObjProp.16.2 Object (%<\\_ObjId " (Get-ObjectIDx64 entnamevla) ">%).Area \\f \"%lu2" "%pr" (itoa precision) "%ps[, m2]%ds44"">%")
PS: you'll also need this line of code after  (vl-load-com)
(defun Get-ObjectIDx64 (obj / util)(setq util (vla-get-Utility (vla-get-activedocument (vlax-get-acad-object))))(if (= (type obj) 'ENAME)(setq obj (vlax-ename->vla-object obj)))(if (= (type obj) 'VLA-OBJECT)(if (> (vl-string-search "x64" (getvar "platform")) 0)(vlax-invoke-method util "GetObjectIdString" obj :vlax-False)(rtos (vla-get-objectid obj) 2 0)))) ; defun Get-ObjectIDx64
Paul Li
IT Specialist
@The Office
Message 14 of 33
Lukasvop1
Now works well, thank you guys for great job.
Message 15 of 33
Lukasvop1
I've got one more issue if change suffix from m2 to m² I get this result..
Message 16 of 33
paullimapa
I’m not at a computer now but try one if the solutions discussed in this thread
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/mm2/m-p/1639312
Paul Li
IT Specialist
@The Office
Message 17 of 33
paullimapa
Looks like the last solution on that thread worked:
"%ps[, m" (chr 178) "]%ds44"">%")
FYI: I also modified the routine to use AutoCAD's built-in geocenter object snap feature to get the pline's center point instead of spending the time calculating it.
Paul Li
IT Specialist
@The Office
Message 18 of 33
Lukasvop1
Thank you, it looks great but still not work for me, I don't know what's wrong?
Message 19 of 33
paullimapa
not sure what the problem is.
what happens when you open my drawing...does it look like this:
Paul Li
IT Specialist
@The Office
Message 20 of 33
paullimapa
FYI, My STANDARD text Style is Arial:
Paul Li
IT Specialist
@The Office
