Autoloader - app.bundle home folder
vladimir_michl
Advisor Advisor
vladimir_michl
Is there a way how to find which directory is the app loaded from? I need a way to point to a specific file in the application's own .bundle folder structure - e.g. to start a specific .exe with (startapp) from the CUI menu macro.
Vladimir Michl
redtransitconsultants
It's one of these 3 locations...
C:\Users\%username%\AppData\Roaming\Autodesk\ApplicationPlugins
C:\Program Files\Autodesk\ApplicationPlugins
C:\ProgramData\Autodesk\ApplicationPlugins
But if you're looking to do it from the code file within CAD, you'll need to do a reflection on the source file. Fairly easy to do in .NET not sure for LISP
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
vladimir_michl
I was thinking of some kind of variable (e.g. in the XML manifest file) saying "I'm sitting here". Another option would be to check all three possible locations.
Vladimir Michl
I'm not sure you can do it in XML coding, even then if you could, how would you store that to call it up in a CUI button? I'm not sure that would work.
For .NET, it's simply:
public static string AssemblyDirectory
    get
        string codeBase = Assembly.GetExecutingAssembly().CodeBase;
        UriBuilder uri = new UriBuilder(codeBase);
        string path = Uri.UnescapeDataString(uri.Path);
        return Path.GetDirectoryName(path);
But if you don't know where it's stored and just looking to create a CUIx button to tell you where it is... then need to have a macro that can check for a file in those 3 locations. I'm not positive that can be done as I've never tried.
Alexander.Rivilis
Variant:
(vl-filename-directory (findfile "<name>.cuix"))
Oops. It is a bad idea. Sorry...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
vladimir_michl
This is what I have tried also. Unfortunately the "home" folder is not in the search path (and adding it would be a chicken-egg problem). I wish there was a mechanism for this as it is quite usual to access individual files from the app folder structure - EXEs, preconfigurations, resources...
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
