AutoLisp to pass block attribute ID name and block count of a specific row to “Putcell” command for the GetExcel routine
rebPTFNF
Message 1 of 24
rebPTFNF
I’m creating a pricing sheet by pulling attribute IDs and their duplicate block count (block instances) from a CAD drawing and putting them into an existing excel file. I think I have most of the separate parts needed but can’t figure out how to put it all together so looking for some help.
These are the Steps I believe are needed in my routine:
  1. Load the GetExcel.lsp functions needed to put info from CAD into existing Excel.
  2. Open Excel to write.
  3. Get attribute ID name from a block. Associate name with a row. EX: ID name “A006” = row 10.
  4. Get duplicate count of that block. Ex: “3”.
  5. Create a loop (foreach?) to add ID name and count into corresponding “Putcell” commands (know by its row number). I can have a putcell command with a row for all 200 ID names.
  6. Save and close Excel.
Here is a mockup image of the end result when blocks with IDs “A002”, “A006”, “A009”, “A012” are found in the attached drawing. (whoops. Cant figure out how to attach a CAD file or excel file here. Sorry. Anyone know?)
What I know:
a) I have a set number of attribute ID names (1 through 200) that I will ever encounter so I know all the possible names and the rows it need to go to. (Ex: ID “A006” goes in row 10).
b) I can make a Putcell command ready for each of those ID names to cover all (1 through 200).
What I don’t know:
c) How to associate block ID name with a row.
d) How to find duplicate block count and associate it with block ID name/row.
e) How to add ID name and count to a putcell command associated by row like this: (PutCell "B10" '("A006" 3)). "A006" will always go with row 10. What Attribute ID names found and the count is the variable that changes for each drawing.
Routine from Getexcel.lsp: Credit Terry Miller
(defun c:MyPricing ()
(defun GetExcel (ExcelFile$ SheetName$ MaxRange$ / Cnt# Column# ColumnRow@ CreateLists:
  CurRegion Data@ ExcelRange^ ExcelValue ExcelVariant^ Max_Range$ MaxColumn# MaxRow#
  Range$ Row# Sheet_Name$ Worksheet)
  ; CreateLists: - Creates Lists of SheetName$ up to MaxRange$ of Excel data
  (defun CreateLists: (Sheet_Name$ Max_Range$ / ReturnList@)
    (if Sheet_Name$
      (vlax-for Worksheet (vlax-get-property *ExcelApp% "Sheets")
        (if (= (vlax-get-property Worksheet "Name") Sheet_Name$)
          (vlax-invoke-method Worksheet "Activate")
        );if
      );vlax-for
    );if
    (if Max_Range$
      (progn
        (setq ColumnRow@ (ColumnRow Max_Range$))
        (setq MaxColumn# (nth 0 ColumnRow@))
        (setq MaxRow# (nth 1 ColumnRow@))
      );progn
      (progn
        (setq CurRegion (vlax-get-property (vlax-get-property
          (vlax-get-property *ExcelApp% "ActiveSheet") "Range" "A1") "CurrentRegion")
        );setq
        (setq MaxRow# (vlax-get-property (vlax-get-property CurRegion "Rows") "Count"))
        (setq MaxColumn# (vlax-get-property (vlax-get-property CurRegion "Columns") "Count"))
      );progn
    );if
    (setq Row# 1)
    (repeat MaxRow#
      (setq Data@ nil)
      (setq Column# 1)
      (repeat MaxColumn#
        (setq Range$ (strcat (Number2Alpha Column#)(itoa Row#)))
        (setq ExcelRange^ (vlax-get-property *ExcelApp% "Range" Range$))
        (setq ExcelVariant^ (vlax-get-property ExcelRange^ 'Value))
        (setq ExcelValue (vlax-variant-value ExcelVariant^))
        (setq ExcelValue
          (cond
            ((= (type ExcelValue) 'INT) (itoa ExcelValue))
            ((= (type ExcelValue) 'REAL) (rtosr ExcelValue))
            ((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue))
            ((/= (type ExcelValue) 'STR) "")
          );cond
        );setq
        (setq Data@ (append Data@ (list ExcelValue)))
        (setq Column# (1+ Column#))
      );repeat
      (setq ReturnList@ (append ReturnList@ (list Data@)))
      (setq Row# (1+ Row#))
    );repeat
    ReturnList@
  );defun CreateLists:
  (if (= (type ExcelFile$) 'STR)
    (if (not (findfile ExcelFile$))
      (progn
        (alert (strcat "Excel file " ExcelFile$ " not found."))
        (exit)
      );progn
    );if
    (progn
      (alert "Excel file not specified.")
      (exit)
    );progn
  );if
  (gc)
  (if (setq *ExcelApp% (vlax-get-object "Excel.Application"))
    (progn
      (vlax-release-object *ExcelApp%)(gc)
    );progn
  );if
  (setq ExcelFile$ (findfile ExcelFile$))
  (setq *ExcelApp% (vlax-get-or-create-object "Excel.Application"))
  (vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Open ExcelFile$)
  (setq *ExcelData@ nil)
  (if (= (type SheetName$) 'LIST)
    (progn
      (if (/= (type MaxRange$) 'LIST)
        (setq MaxRange$ (list MaxRange$))
      );if
      (setq Cnt# 0)
      (repeat (length SheetName$)
        (setq Sheet_Name$ (nth Cnt# SheetName$))
        (setq Max_Range$ (nth Cnt# MaxRange$))
        (princ (strcat "\nImporting " (vl-filename-base ExcelFile$) " - " Sheet_Name$ " data..."))(princ)
        (setq ReturnList@ (CreateLists: Sheet_Name$ Max_Range$))
        (setq *ExcelData@ (append *ExcelData@ (list ReturnList@)))
        (setq Cnt# (1+ Cnt#))
      );repeat
    );progn
    (progn
      (if SheetName$
        (progn (princ (strcat "\nImporting " (vl-filename-base ExcelFile$) " - " SheetName$ " data..."))(princ))
      );if
      (setq *ExcelData@ (CreateLists: SheetName$ MaxRange$))
    );progn
  );if
  (vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") 'Close :vlax-False)
  (vlax-invoke-method *ExcelApp% 'Quit)
  (setq *ExcelApp% nil)
  *ExcelData@
);defun GetExcel
; GetCell - Returns the cell value from the *ExcelData@ list
; Arguments: 1
;   Cell$ = Cell ID
; Syntax example: (GetCell "E19") = value of cell E19
(defun GetCell (Cell$ / Column# ColumnRow@ Return Row#)
  (setq ColumnRow@ (ColumnRow Cell$))
  (setq Column# (1- (nth 0 ColumnRow@)))
  (setq Row# (1- (nth 1 ColumnRow@)))
  (setq Return "")
  (if *ExcelData@
    (if (and (>= (length *ExcelData@) Row#)(>= (length (nth 0 *ExcelData@)) Column#))
      (setq Return (nth Column# (nth Row# *ExcelData@)))
    );if
  );if
  Return
);defun GetCell
; OpenExcel - Opens an Excel spreadsheet
; Arguments: 3
;   ExcelFile$ = Excel filename or nil for new spreadsheet
;   SheetName$ = Sheet name or nil for not specified
;   Visible = t for visible or nil for hidden
; Syntax examples:
; (OpenExcel "C:\\Temp\\Temp.xlsx" "Sheet2" t) = Opens C:\Temp\Temp.xlsx on Sheet2 as visible session
; (OpenExcel "C:\\Temp\\Temp.xlsx" nil nil) = Opens C:\Temp\Temp.xlsx on current sheet as hidden session
; (OpenExcel nil "Parts List" nil) =  Opens a new spreadsheet and creates a Part List sheet as hidden session
(defun OpenExcel (ExcelFile$ SheetName$ Visible / Sheet$ Sheets@ Worksheet)
    (if (findfile ExcelFile$)
      (setq *ExcelFile$ ExcelFile$)
      (progn
        (exit)
      );progn
    );if
    (setq *ExcelFile$ "")
  );if
  (gc)
    (progn
    );progn
  );if
  (if ExcelFile$
      (vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Add)
    );if
  );if
  (if Visible
    (vla-put-visible *ExcelApp% :vlax-true)
  );if
  (if (= (type SheetName$) 'STR)
    (progn
      (vlax-for Sheet$ (vlax-get-property *ExcelApp% "Sheets")
        (setq Sheets@ (append Sheets@ (list (vlax-get-property Sheet$ "Name"))))
      );vlax-for
      (if (member SheetName$ Sheets@)
          (if (= (vlax-get-property Worksheet "Name") SheetName$)
          );if
        );vlax-for
        (vlax-put-property (vlax-invoke-method (vlax-get-property *ExcelApp% "Sheets") "Add") "Name" SheetName$)
      );if
    );progn
  );if
  (princ)
);defun OpenExcel
; PutCell - Put values into Excel cells
; Arguments: 2
;   StartCell$ = Starting Cell ID
;   Data@ = Value or list of values
; Syntax examples:
; (PutCell "A1" "PART NUMBER") = Puts PART NUMBER in cell A1
; (PutCell "B3" '("Dim" 7.5 "9.75")) = Starting with cell B3 put Dim, 7.5, and 9.75 across
(defun PutCell (StartCell$ Data@ / Cell$ Column# ExcelRange Row#)
  (if (= (type Data@) 'STR)
    (setq Data@ (list Data@))
  (setq ExcelRange (vlax-get-property *ExcelApp% "Cells"))
  (if (Cell-p StartCell$)
    (setq Column# (car (ColumnRow StartCell$))
          Row# (cadr (ColumnRow StartCell$))
    );setq
    (if (vl-catch-all-error-p
          (setq Cell$ (vl-catch-all-apply 'vlax-get-property
            (list (vlax-get-property *ExcelApp% "ActiveSheet") "Range" StartCell$))
          );setq
        );vl-catch-all-error-p
        (alert (strcat "The cell ID \"" StartCell$ "\" is invalid."))
        (setq Column# (vlax-get-property Cell$ "Column")
              Row# (vlax-get-property Cell$ "Row")
        );setq
    );if
  );if
  (if (and Column# Row#)
    (foreach Item Data@
      (vlax-put-property ExcelRange "Item" Row# Column# (vl-princ-to-string Item))
    );foreach
  );if
  (princ)
);defun PutCell
; CloseExcel - Closes Excel spreadsheet
; Arguments: 1
;   ExcelFile$ = Excel saveas filename or nil to close without saving
; Syntax examples:
; (CloseExcel "C:\\Temp\\Temp.xlsx") = Saveas C:\Temp\Temp.xlsx and close
; (CloseExcel nil) = Close without saving
(defun CloseExcel (ExcelFile$ / Saveas)
  (if ExcelFile$
    (if (= (strcase ExcelFile$) (strcase *ExcelFile$))
        (vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") "Save")
        (setq Saveas t)
      );if
        (progn
          (vl-file-delete (findfile ExcelFile$))
          (setq Saveas t)
        );progn
        (setq Saveas t)
      );if
    );if
  );if
  (if Saveas
      "SaveAs" ExcelFile$ -4143 "" "" :vlax-false :vlax-false nil
    );vlax-invoke-method
  );if
  (setq *ExcelApp% nil *ExcelFile$ nil)
  (princ)
);defun CloseExcel
; ColumnRow - Returns a list of the Column and Row number
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
;   Cell$ = Cell ID
; Syntax example: (ColumnRow "ABC987") = '(731 987)
(defun ColumnRow (Cell$ / Column$ Char$ Row#)
  (setq Column$ "")
  (while (< 64 (ascii (setq Char$ (strcase (substr Cell$ 1 1)))) 91)
    (setq Column$ (strcat Column$ Char$)
          Cell$ (substr Cell$ 2)
    );setq
  );while
  (if (and (/= Column$ "") (numberp (setq Row# (read Cell$))))
    (list (Alpha2Number Column$) Row#)
    '(1 1);default to "A1" if there's a problem
  );if
);defun ColumnRow
; Alpha2Number - Converts Alpha string into Number
; Arguments: 1
;   Str$ = String to convert
; Syntax example: (Alpha2Number "ABC") = 731
(defun Alpha2Number (Str$ / Num#)
  (if (= 0 (setq Num# (strlen Str$)))
    0
    (+ (* (- (ascii (strcase (substr Str$ 1 1))) 64) (expt 26 (1- Num#)))
       (Alpha2Number (substr Str$ 2))
  );if
);defun Alpha2Number
; Number2Alpha - Converts Number into Alpha string
; Arguments: 1
;   Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC"
(defun Number2Alpha (Num# / Val#)
  (if (< Num# 27)
    (chr (+ 64 Num#))
    (if (= 0 (setq Val# (rem Num# 26)))
      (strcat (Number2Alpha (1- (/ Num# 26))) "Z")
      (strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
    );if
  );if
);defun Number2Alpha
; Cell-p - Evaluates if the argument Cell$ is a valid cell ID
; Arguments: 1
;   Cell$ = String of the cell ID to evaluate
; Syntax examples: (Cell-p "B12") = t, (Cell-p "BT") = nil
(defun Cell-p (Cell$)
  (and (= (type Cell$) 'STR)
    (or (= (strcase Cell$) "A1")
      (not (equal (ColumnRow Cell$) '(1 1)))
    );or
  );and
);defun Cell-p
; Row+n - Returns the cell ID located a number of rows from cell
; Arguments: 2
;   Cell$ = Starting cell ID
;   Num# = Number of rows from cell
; Syntax examples: (Row+n "B12" 3) = "B15", (Row+n "B12" -3) = "B9"
(defun Row+n (Cell$ Num#)
  (setq Cell$ (ColumnRow Cell$))
  (strcat (Number2Alpha (car Cell$)) (itoa (max 1 (+ (cadr Cell$) Num#))))
);defun Row+n
; Column+n - Returns the cell ID located a number of columns from cell
; Arguments: 2
;   Num# = Number of columns from cell
; Syntax examples: (Column+n "B12" 3) = "E12", (Column+n "B12" -1) = "A12"
(defun Column+n (Cell$ Num#)
  (strcat (Number2Alpha (max 1 (+ (car Cell$) Num#))) (itoa (cadr Cell$)))
);defun Column+n
; rtosr - Used to change a real number into a short real number string
; stripping off all trailing 0's.
; Arguments: 1
;   RealNum~ = Real number to convert to a short string real number
; Returns: ShortReal$ the short string real number value of the real number.
(defun rtosr (RealNum~ / DimZin# ShortReal$)
  (setq DimZin# (getvar "DIMZIN"))
  (setvar "DIMZIN" 8)
  (setq ShortReal$ (rtos RealNum~ 2 8))
  (setvar "DIMZIN" DimZin#)
  ShortReal$
);defun rtosr
(princ);End of GetExcel.lsp
(OpenExcel "C:\\TEMP\\MyBlock_Att_Test.xlsx" "MainSheet" nil);Open Excel file
; This is where I need help finding block info and adding to Putcell command
;;;;Example of putting in info from CAD to excel;;;;;
;;;;Example;;;;;
(CloseExcel "C:\\TEMP\\MyBlock_Att_Test.xlsx");Close Excel
);End MyPricing
Here are some routines I was looking at in order to grab the block info needed.
Block attribute ID name:
Here is one from Lee Mac that finds Attribute IDs and saves to variable “data”. I took out the excel export part since that can be handled by Getexcel.lsp routine.
;; Text 2 CSV  -  Lee Mac
;; Writes all Text, MText & Attribute content from all layouts and within
;; all blocks and nested blocks to a selected CSV file.
(defun c:txt2csv ( / data file )
    (cond
        (   (not
                (progn
                    (vlax-for block (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
                        (if (eq :vlax-false (vla-get-isxref block))
                            (vlax-for obj block
                                (cond
                                    (   (wcmatch (vla-get-objectname obj) "AcDb*Text")
                                        (setq data (cons (vla-get-textstring obj) data))
                                    (   (and
                                            (eq "AcDbBlockReference" (vla-get-objectname obj))
                                            (eq :vlax-true (vla-get-hasattributes obj))
                                        (foreach att (vlax-invoke obj 'getattributes)
                                            (setq data (cons (vla-get-textstring att) data))
                    data
            (princ "\nNo Text, MText or Attributes found.")
        (   (not (setq file (getfiled "Create CSV file" "" "csv" 1)))
            (princ "\n*Cancel*")
        (   (setq file (open file "w"))
            (foreach x data (write-line x file))
            (setq file (close file))
            (princ (strcat "\n" (itoa (length data)) " strings written to file."))
        (   (princ "\nUnable to open CSV file for writing."))
    (princ)
(vl-load-com) (princ)
Block count.
Here is another one from Lee Mac that list the count by its block name (but not attribute ID). Block Name will already be listed in correct row under column A in spreadsheet. Just need to add corresponding ID name ex: “A006” in Column B/row 10 and count “3” in Column C/row 10 through the Putcell command. EX: (PutCell "B10" '("A006" 3)). I guess I could associate Block name to Block Attribute ID and also to row. The count would be the only variable really thats unknown for each.
(defun c:myblockcounter ( / blk idx itm lst sel )
    (if (setq sel (ssget '((0 . "INSERT"))))
        (repeat (setq idx (sslength sel))
            (setq blk (cdr (assoc 2 (entget (ssname sel (setq idx (1- idx)))))))
            (if (setq itm (assoc blk lst))
                (setq lst (subst (cons blk (1+ (cdr itm))) itm lst))
                (setq lst (cons  (cons blk 1) lst))
    (foreach itm lst (princ (strcat "\n" (car itm) ": " (itoa (cdr itm)))))
    (princ)
Any help is greatly appreciate!
Replies (23)
Message 21 of 24
pbejse
@rebPTFNF wrote:
It works! This is Awesome! Changing the filter did the trick. It finds any matching block from the Excel template, puts in the tag and the count from the drawing.
Happy to hear that it all works out for you.
I have posted this question on many other forums looking for this answer. I would like to post your solution you created for others who might be seeking the same question...
I dont mind you posting the solution on other forums, but I'd rather have you post  a link to this topic.
More visitors for us here 🙂
@rebPTFNF wrote:
Thanks again!!!
Its my pleasure, Glad i could help
Message 22 of 24
rebPTFNF
Hey Guys. Thank you again for your help. I’m attempting to modify the routine in order to create a simple strip down version for a "quick block check" routine (with only the drawing block info and no pricing) in a blank excel file. Instead of matching block names, just putting any block name found with its corresponding Att ID and count (if available).
First, trying to understand the procedure in original routine…
  1. dataSource stores CAD drawing info. dataTarget stores Excel info.
  2. dataSource variable stores all inserted block and its attributes in drawing through assoc (“0”, “66”).
  3. Data variable stores Excel info from dataTarget and passes to blst variable
  4. Variable ev stores all the entity names in drawing from dataSource.
  5. Variable bname stores block name pulled from ev.
  6. Do a search in whatever is in bname and set to blst
  7. Variable Attv stores ID pulled from ev through GetAttributes
  8. Set variable f to value in Attv (ID info)
  9. Set variable fd to bname
  10. Variable data then updates f and fd with block count using subst to latest info.
  11. Open Excel
  12. foreach loop grabs what’s in data (4 levels down) and save it in variable itm
When block name stored in itm matches name in blst, use specific List type to pull out ID (and its Count) from itm and put in respective column B and C in Excel using PutCell function. Repeat loop.
13. Close Excel. Open saved Excel file.
Next, I need to see what’s needed to modify above procedure to make a “quick block check” routine that will create an Excel file that has only the following:  block name, ID and count for columns A, B and C.
Changes:
-Won’t need to compare any info from an excel file since it’s a blank file (do I even need a template then?).
-Modify loop. No need to compare itm to blst. Just a loop to put info from itm into cells A, B and C.
-Add another PutCell command (using cadr list type?) to pull out block name from itm and put in column A. EX: (PutCell (strcat "A" (car itm)) (Cadr itm))
Questions:
Do I need the blst variable since Excel file would be blank?
Block name is in variable bname as well as buried in itm list variable (along with ID and count i.e f and fd)?
If pulling block name from itm, use the car or the cadr list type?
How do I modify the foreach loop if I’m not comparing itm to blst to figure out placement in Excel?
Not sure how to direct where to start putting the info into excel if there is no name compare. Will it always start at A1? And then automatically go to B1 next…
Thanks in advance for your patience…!
Message 23 of 24
rebPTFNF
  11. Open Excel
Changes:
Questions:
Message 24 of 24
rebPTFNF
  11. Open Excel
Changes:
Questions:
