AutoLisp - Text to Block Attribute
eduardosforni
eduardosforni
Hi!
I need a lisp routine that change a bulk of blocks attribute based on list of text previously selected, someone know a lisp routine does that?
Example.:
I select some texts then
select the same number of blocks
press enter
then the previously selected texts become the sixth attribute of my block.
Thank you
the thing can be easy done if you want to select a text and use it as attribute but how do u think to chose which text will be used for each block?
ВeekeeCZ
Here's the code. Fill up a TAG of your 6th att.
(defun c:TextToBlock ( / s e)
  (if (and (setq s (ssget '((0 . "TEXT"))))
	   (setq e (entsel "\nSelect a block: "))
    (setpropertyvalue e "TagOfYour6thAtt" (cdr (assoc 1 (entget (ssname s 0))))))
  (princ)
