Autolisp returns values of attribute block
I am looking for a lisp-program, which fuctions in dwg-drawing as follows:
There are 250 pcs round steel poles as a plan view.  Pole and pole’s number are as an attribute block.
We should now make a list in the dwg, which contains pole’s number and pole’s coordinates x and y.
I appreciate, if someone has something like this to share.
BR
Kari Rantanen
ВeekeeCZ
You don't need LISP at all. Use the DATAEXTRACTION command.
See the SCREENCAST
From the DE you can export a table directly into drawing (would be interactive!), or to xls or csv and adjust a table in Excel...
Thanks! That was great.
Kari Rantanen
