Autolisp Mouse Left Click?
anieves228
anieves228
Hello all,
I am trying to initiate or simulate a left mouse click. Similar to "" for spacebar/enter. Is this possible? I cant find much on this.
Thank you!
Kent1Cooper
Can you just give it XY coordinates?  That's what would be returned by a left-click when in a command that's looking for a location.  If you mean it for object selection by having the routine find something at a given location without your needing to pick on it, look into (nentselp), which can pick an object for you given the coordinates of where to pick it.  [For some reason there's no non-nested (entselp) function, but (nentselp) will see a top-level object if it's not nested.]  Or do you have some other kind of left-click purpose in mind?
Kent Cooper, AIA
anieves228
My application is rather simple. Really just placing a text box. I did it with single-line text (as shown below). The command places text at the appropriate size and with the proper text style. I would like to do this with Multiline text. So all I would need is a left click for the second click for the text box size during the _mtext command.
	(DEFUN C:T1 ()
  	(SETVAR "CMDECHO" 0)
		(C:TERRA01) ;Creates 0.1" Text style
		(C:annoscale) ;Sets annotation scales
		(PROMPT "INSERT 0.1 TEXT")
    (COMMAND "-LAYER" "M" "DWG-TEXT-GENERAL" "L" "CONTINUOUS" "" "LW" "0" "" "S" "0" "")
			(SETVAR "CLAYER" "DWG-TEXT-GENERAL")
			(COMMAND "TEXT" "S" "TERRA 0.1" PAUSE "0" "INSERT TEXT")
		(SETVAR "CMDECHO" 1)
		(PRINC)
Kent1Cooper
If you don't expect the Mtext to need to word-wrap, you can use the Width option and give it zero for the width, to avoid the need to pick a second point:
(COMMAND "_.MTEXT" pause "_style" "TERRA 0.1" "_width" 0 "INSERT TEXT" "")
Or if you have a known width for the text box, you can give it that with a relative displacement [only the X part matters]:
(COMMAND "_.MTEXT" pause "_style" "TERRA 0.1" "@4,0" "INSERT TEXT" "")
You just need to be aware of the sequence of prompts [for example, that you must pause for the first point before the Style option unlike in a TEXT command, and you must invoke the Style option before giving it the second point].
P.S.  If this:
makes that Style current in the process, then you don't need to specify the Style within the Text/Mtext command.
Kent Cooper, AIA
anieves228
Ah ok perfect! Thank you!
This does not make the style current. it just creates it. I made this for it to be mainly called when I do other commands. Such as inserting a layout with a border template to make sure all the text has a style to reference.
Sea-Haven
If the function only creates the text style use
(setvar 'textstyle "Your style name")
