AutoLISP Extension for VS code
Moshe-A
Mentor Mentor
Message 1 of 8
Moshe-A
Guys hi,
This weekend i finally moved to VS Code, looks wonderful as with the features for debugging, watch variables at run time but i miss the console window of VLIDE
is there something that replace it?
Another issue:
i configure VS Code for AutoLISP as instructed in >> document << including setting default language for 'autolisp' but still when opening a new text file it does not default to .lsp what i am missing?
thanks in advance
Moshe
Replies (7)
Message 2 of 8
paullimapa
If you hit Ctrl+Shift+X combination on your keyboard and you see AutoCAD Autolisp Extensions listed then you're not missing anything:
Keep in mind that VS Code is not designed to just edit lisp code so when you select File>Open File it'll always show All Files (*.*) as the filetypes to list:
When you want to start a new AutoLISP code select File>New Text File
You'll be prompted to Select a Language:
After you click on Select a Language a dropdown window opens for you to select AutoLISP
Now when you start entering an AutoLISP function a window appears with a list of matching functions for you to select from:
Paul Li
IT Specialist
@The Office
Message 3 of 8
ec-cad
In the document you linked here, it says:
"After creating a new file, you should save the file with the .lsp file extension"
So, the program defaults to plain text - probably .txt file extension.
ECCAD
Message 4 of 8
Moshe-A
@paullimapa  hi,
paul: "You'll be prompted to Select a Language"
thank you for that but on my VS code is does not pop that menu, maybe i am missing some setting?
Message 5 of 8
Moshe-A
@ec-cad  hi,
thanks
see my link at the bottom is says : Now when a new file is created in VS Code, it will default to the 'AutoLISP' format without first saving the file.
maybe 'AutoLISP' format means something else other then .LSP ?
does this works for you?
Message 6 of 8
paullimapa
That's odd...again here are the steps I take to start a new file with VS Code window opened:
1. Click on File>New Text File or Ctrl+N keyboard combination:
2. I then get an Untitled-1 tab for the new document and at the first row of this new blank page I see the Select a Language text option
3. By default the current Language Mode can be seen in the lower right hand corner of the VS Code window which in this case is Plain Text
4. Since you don't see the Language Mode selection option, you can actually click on the Plain Text in the status bar at the lower right hand corner and in the middle of the top bar will drop down a window for you to select the Language Mode:
Likewise, after opening a file that has a .lsp file extension VS Code should automatically recognize this as AutoLISP because you have that extension installed:
If you want to change this Language Mode, you can also select AutoLISP in the status bar in the lower right hand corner and again the dropdown window appears for you to select another Language Mode:
Paul Li
IT Specialist
@The Office
Message 7 of 8
Moshe-A
@paullimapa + @ec-cad  hi,
Here is an update...when selecting  New Text File     Ctrl+N  (as i said i do not see select language) at the bottom left i see Autolisp as
Select language mode this i assume is the result of settings autolisp in Preferences\settings\Default language field.
when i pick File\save the default offered is .lsp so i think i will settle with this 😀
Thank you very much guys
Moshe
Message 8 of 8
paullimapa
Looks like you got it…cheers!!!
Paul Li
IT Specialist
@The Office
