Autolisp - Change value in coordinates
traci_haberghamJQEJT
Good morning all,
I'm looking to create a command to rule a line either in the x or y direction from the initial point that the user chooses.
I can get the point but I'm unsure on the best way to update the value within the co-ordinates!
What is the best way to add 20000 to the x value of a coordinate?
Thank you
Traci
Accepted solutions (3)
tramber
I use this :
(defun +x (pt val) (cons(+(car pt)val)(cdr pt)))
It gives :
(+x '(0 0 0) 10) -> (10 0 0)
(+x  pointA  added_value)
Is the code.
Kent1Cooper
@traci_haberghamJQEJT wrote:
.... from the initial point that the user chooses. ....
(polar UserPoint 0 20000)
or for the Y value instead:
(polar UserPoint (/ pi 2) 20000)
Or:
(mapcar '+ UserPoint '(20000 0 0))
(mapcar '+ UserPoint '(0 20000 0))
Kent Cooper, AIA
john.uhden
@traci_haberghamJQEJT ,
You don't necessarily need AutoLisp to do what you want.
Just make sure that Orthomode is on (F8)
Then pick your starting point,
Then aim your cursor either up/down or left/right and type in the length.
John F. Uhden
Sea-Haven
This will add a value to the point selected, maybe can be used transparently.
(mapcar '+ (getvar 'lastpoint) (list 20000 0.0 0.0))
(defun c:20000 ( / )
(command "line" (getpoint "\nPick 1st point "))
(command (mapcar '+ (getvar 'lastpoint) (list 20000 0.0 0.0)) "")
There is a way using a reactor that you could type Lxxx and it will draw a line xxx length in X direction.  Maybe better as X1200 then can have Y1000 and so on. Will leave it to others to have a go at modifying code provided. Load the lisp and type X20000 on command line. or X1000 and so on. Note if want decimals must do like this 123-4 use a "-" for decimal point.
That's great, thank you.  It halves the amount of clicks the user has to do.
