AutoLISP - Adding DXF code 48 to entities....
eelrod
eelrod
Hello, I'm realitively new to AutoLISP.
What I would like to do is change certain entity's linetype scale override with LISP.  The problem I'm having is that if an entity's LTScale is the default, it has no LTScale override and no DXF code 48 to modify with entmod.
Is there a way to add DXF code 48 to an entity?
Thank you kindly!
hmsilva
Try
(if (assoc 48 ent)
   (entmod (subst (cons 48 3) (assoc 48 ent) ent))
   (entmod (append ent (list (cons 48 3))))
Hope this helps,
Henrique
scot-65
In lieu of CONS, try APPEND.
(entmod (append d1 (list (cons dfx new))))
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
eelrod
Thank you, that is exactly what I needed!
hmsilva
You're welcome, evan.elrod
Glad I could help
Henrique
