Autocad Script load
Autocad Script load
jonathan_petitclerc
Autocad Script load
jonathan_petitclerc
I made a macro in a tool palette button to load a script :
^C^Cload"X:/filepath/scriptfile.scr";
But when I click on it, I receive the error; Unknown command "SCR"
I tried running the script directly and it works fine... So it is something that I did with the macro...
tramber
No LOAD but SCRIPT instead should work
LOAD is not intended for scripts.
paullimapa
The solution is in the way you ran "the script directly."  The command you used to run the script should be the same command you use and include in the macro.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
cadffm
No LOAD but SCRIPT..
And I am missing the ENTER after your command SCRIPT (not load)
^C^C_.SCRIPT;"X:/Path/filename.scr"
Sebastian
tramber
Yes CADffm is right. I forgot to tell.
You can either use space :
^C^C_.SCRIPT "X:/Path/filename.scr"
