Autocad Script File - Windows 7 <> Windows 10
mdhutchinson
Advisor Advisor
mdhutchinson
What is going on here I am wondering.
I have built a script file that I've ran under Windows 7 that I'd been using for years without issue. Much of it is driven by Action Recorder macros.
However, under Windows 10 the Action Macros do not run.
Please help!
dennis
Two thoughts that comes to mind,
1) .NET Framework.  I have seen where if the PC OS was upgraded from Win 7, then Win 8.1, then Win 10, all seems fine.  But on new PCs with Win 10, things go weird.  The fix was to uninstall the .NET Framework, then install first .NET Framework 4, then upgrade it along through each of the versions.
If this fits your scenario, then it may be worth the uninstall/install process.
2) Another thing I have found is when the PC did go through the OS upgrade process from Win 7 to Win 10, the user profile gets "messed up" and creating a new user profile "fixes" the weirdness.
