Autocad removes space at end of filename.
I have a lisp routine that works on dwg files, and then saves back as the original file name.
When there is a space at the end of the file name, autocad removes it. This is not acceptable, as it creates 2 files in the folder.
The simple lisp function of
(command "save" "test  .dwg")
Will save the dwg as "test.dwg". Not acceptable.
Thanks.
Shneuph
Can you use (chr 32) instead of the " " spaces?
(command "save" (strcat "test" (chr 32) ".dwg"))
(untested)
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
No luck with that solution.
I found a workaround with the  (vla-saveas (vla-get-ActiveDocument (vlax-get-Acad-Object))  "dwgname .dwg")
Not great, but it works.
