AutoCad read values of a certain cells in Excel
Message 1 of 11
I am looking for a way in lisp to have AutoCad read values of a certain cells in Excel.
something along the lines of
(setq cust_name (MI_askstrng "Enter Customer Name.....:"))
but instead of "Enter Customer Name", I would like it to read chosen Excel Doc, Sheet 1, Cell B2.
Replies (10)
Message 2 of 11
dbhunia
Check This
Debashis Bhunia
Co-Founder of Geometrifying Trigonometry(C)
________________________________________________
Walking is the First step of Running, Technique comes Next....
Message 3 of 11
Thank you for your reply i have one more doubt if i do not want to select a file and want the program to directly open the file from a folder,
(setq fileName(getfiled "Select Excel File" "C:\Support\LISP FILES\data.xlsx" "xlsx" 16))
the above code is not working and it is still asking me to select, thanks in advance
Message 4 of 11
dbhunia
use this
To select File Directly - (setq fileName "C:\\Support\\LISP FILES\\data.xlsx")
To select Sheet Directly -(setq sheetName "Sheet Name")
Debashis Bhunia
Message 5 of 11
Thank you now there is no need to select the file again and again but
whwnever i select the cell it shows-
; error: bad argument type: VLA-OBJECT #<%catch-all-apply-error%>
Message 6 of 11
dbhunia
Make sure about "Entered File Path" & "Sheet Name" existence.
Debashis Bhunia
Message 7 of 11
it seems like the problem is with this line
;;;--- Get the excel file
(setq fileName "C:\\Support(WL)\data.xls")
 but i am not sure what
Message 8 of 11
dbhunia
It should be.......
(setq fileName "C:\\Support(WL)\\data.xls")
Debashis Bhunia
Message 9 of 11
i have a doubt, can you please explain what is the meaning of the code-
cus_name (MI_askstrng "Enter Customer name....:" (nth 0 #TTLE))
#TTLE (LI_RepList #TTLE 1 cus_name)
Message 10 of 11
dbhunia
I did not get all the things .......
post the code......
Debashis Bhunia
Message 11 of 11
JBerns
@dbhunia,
Do you know where else I may search for Jeffery P Sanders AutoLISP collection for reading and searching Excel (XLS/XLSX) files? The link in your message reports the site can't be reached. Perhaps the site is just temporarily down.
Thank you for your time and attention. I look forward to your reply.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
