(AUTOCAD MEP) lisp to replace "any block" with any "device"
jtm2020hyo
jtm2020hyo
(AUTOCAD MEP) lisp to replace "any block" (regular, dynamic) with any "device" (for MEP)
I already tried to command REPLACEBLOCK but does not work.
help, please.
3wood
I guess you can make a new block from the "device". Then do the block replacement. Explode the block after the replacement.
pendean
Community Legend
Community Legend
jtm2020hyo
Thanks for your interesting
sadly you're suggesting does not work because AutoCAD MEP has objects called "devices"
"devices" it's like a dynamic block in a 99% but is not considered a dynamic block for AUTOCAD
...so the command REPLACEBLOCK does not work here.
I can explore the "device" and obtain the block inside the object but without their other properties
...I do not need the block, I need the "device" one with all their properties. In my case, I need lighting wiring properties.
AUTOCAD MEP it's like REVIT MEP
3wood
Sorry my post was not very clear.
Make a new Block A, the content of the block is your "device". So the "device" is inside the Block A.
jtm2020hyo
This is not what I was looking for, but works.
If someone has Lisp for doing this directly, humanity will be grateful.
