Autocad macros
Autocad macros
Autocad macros
Hello All When i try to code macro in Autodesk and customized it, is it possible that i can do it all the commands ? After the coding is done in autocad and i draft a drawing,  then can i extract the values of the drawing from the autodesk macros ? If yes/ no , then in which form and type.
pendean
Community Legend
Community Legend
Autodesk is a company name: do you know what software you are actually using?
What do you want to customize exactly?
Can you share the macro code that fails and explain why it fails?
i am using autocad software. tried data extraction method it worked.  Can macros be coded for all commands and then can i extract the values of the drawing from the autocad macros ? If yes/ no , then in which form and type.
pendean
Community Legend
Community Legend
Macros are only possible with commands that do not use pop-ups or dialog boxes.
